DynoFlash [Visit Site]
Large Injectors Needed Yet?
Old Jan 23, 2006 | 07:50 PM
DrBump471's Avatar
Hey Al, (and fellow Dynoflashers)
I am currently running the following mods on one of your Custom Dynoflash Street Tunes
Helix O2 Housing
Helix 3" Downpipe
UR 3" High Flow Cat
Blitz Nur Spec Catback Exhaust
Blitz SUS Intake
HKS 272's I/E Cams w/ARP Headbolts
SMC Methanol Kit (100% Meth)
Blitz SBC-iD Boost Controller
Greddy RS BOV
Walbro 255 LPH Fuel Pump
Things I am about to add and get a reflash from Al
3" Testpipe
Turbo XS FMIC
AMS Lower Intercooler Pipe
With what I have and what I am getting do you think larger injectors are needed yet?
If so how large?
Thanks,
DrBump
Old Jan 24, 2006 | 10:25 AM
DrBump471's Avatar
bump for some help?
Old Jan 24, 2006 | 10:32 AM
thatsMR2u's Avatar
since your running methanol you might not even need injectors but 680cc should be the largest you would need
Old Jan 24, 2006 | 10:33 AM
smokedmustang's Avatar
NO! Not until you get a LARGER turbo. I still have my stock injectors!my 2c.
Old Jan 24, 2006 | 10:50 AM
evowilling's Avatar
Old Jan 24, 2006 | 04:01 PM
DrBump471's Avatar
Smoked - do you know what your duty cycle is at? I am sure we are pretty similar.
I thank everyone so far for their remarks
Old Jan 24, 2006 | 04:55 PM
Andrew at Dyno4mance does, I think damn close, but not yet maxed out.Still a little room left. but EVERYONE told me injectors arent needed till bigger turbo. I will find out and let you know. Later!
Impressive signature Bumper, now you need stickers!!
Old Jan 24, 2006 | 05:10 PM
DynoFlash's Avatar
Stay with the stock injectors when you have alochol for sure
Old Jan 24, 2006 | 05:47 PM
DrBump471's Avatar
Thanks Smoked!!
Al, thanks for the input. I will keep the stock injectors. I will let you know when I have added the new parts as I will be getting it reflashed via mail.
Thanks again!!
Old Jan 25, 2006 | 10:19 AM
honki24's Avatar
please dont say these things till you actually log your stock injector duty cycle... I am on stock turbo, w/ WI, so I run 24 psi, but even at 20 psi and only cams/tbe/intake... and the like I was definately pegging the stock 560's out. upgrad them. the only thing in the stock defense is that I never went lean even though I was running them at 100%. So I believe that if nothing extraordinary happens and all works fine, nothing will be damaged... but do you really wanna run em at 100%?
Old Jan 25, 2006 | 02:59 PM
DrBump471's Avatar
honki24 - are you running just water or methanol as your fluid of injection?
This may make a difference in what the duty cycle is on the injectors since Smoked and I are running straight methanol.
Old Jan 25, 2006 | 03:16 PM
You must know more than all the top speed shops then! I will go with their reccomendations on this one. Thanks Bumper asked if they are NEEDED, and NO they are not. you need MORE air to mix with the "more" fuel being dumped in,(the more air volume will be found with a BIGGER TURBO) and there is no need for more fuel, if you have a constant (stock) amount of air to mix with it.my 2c. I have been running fine with my mods, and stock injectors for over 2 years, I stomp on it hard, and have an AEM UEGO guage on my dash, and I run richer without any problems with the boost. I am at 97-99%? Call Andrew, he will tell you its OK to keep the stockers, and I can mention ALL the other speedshops if you want me too.
Old Jan 25, 2006 | 04:00 PM
DynoFlash's Avatar
true - those usuing water mix will require more fuel
