DynoFlash [Visit Site]
got cams changed out....
Old Feb 4, 2006 | 07:52 AM
Corey's Avatar
I recently had my 264's swapped out for 272's. Actually I had it done on Thursday. Yesterday, my SES light came on and I went to a shop and had the scanner put on it. It was the P0300 random misfire code. I just changed my plugs (BPR7ES) not too long ago. I have them gapped to .26 and they are MAYBE 2 months old. I'm thinking the code came up while the car was idling, but I'm not sure cause my gauge pod blocks it so I don't really notice it. This is the 3rd time in the almost 3 years I've owned the car I've had a random misfire code and everytime changing the plugs has fixed it.
Now for my question. Since I swapped cams, should I be running a different plug or maybe the plugs need to be regapped? If so, what plugs or gapping is good to run?
My mods are:
HKS RS intake
Helix downpipe
Perrin Test pipe
HKS cat back
HKS 272's
Walbro
HKS evc-v
and a custom DynoFlash (for my 264's)
I was actually thinking of getting retuned, but I'm in the process of maybe buying a TME turbo so I'd rather wait til I get that and get it tuned for everything at one time.
Thanks,
Corey
Old Feb 4, 2006 | 08:33 AM
brokeazzlos's Avatar
get the reflash from the dealership.
Old Feb 4, 2006 | 10:20 AM
DynoFlash's Avatar
Get the dealership 0300 update and send in the ecu to have your flash applied ontop of that
Old Feb 4, 2006 | 10:21 AM
DynoFlash's Avatar
of just ignore the 0300 code problem - it has no effect on how the car drives
Old Feb 4, 2006 | 10:32 AM
AndyBandy's Avatar
i would think .26 is a bit high...try experimenting with .23 - .24
Old Feb 4, 2006 | 11:11 AM
Corey's Avatar
Okay....I'm gonna play with the gapping first and see if that helps. If not, I'll be contacting you to find a good time to ship it to you.
Thanks for the replies.
EDIT: If I send it in, would that count as my free upgrade from when I got custom tuned? Do you think the custom tune for my 264's would be fine our could I gain anyhting from a another map from someone else?
Old Feb 4, 2006 | 11:22 AM
Jakeg97's Avatar
Spark plug gap: 0.7 - 0.8 mm (0.028 - 0.031 inch)
taken from the service manual
Old Feb 4, 2006 | 12:34 PM
Jim_Patterson's Avatar
Its a little different when the car isnt stock and is making more power, requires more from your ignition system.
Old Feb 4, 2006 | 01:54 PM
Corey's Avatar
Yeah....service manual setting are for stock cars. Mine isn't so stock anymore.
Old Feb 4, 2006 | 07:17 PM
tequila083's Avatar
I had the p0300 cel but also had misfire between 2000-3000rpm. This happen everytime i hit the highway. I dont have cams. I change spark, spark plugs wire, different spark gaps all of this with no luck. i took mitsubishi flash and i have to weeks without cel or misfire.
Old Feb 4, 2006 | 08:25 PM
mhgsx's Avatar
I would think the more important question should be: Do you notice any extra HP??
Old Feb 4, 2006 | 09:35 PM
Corey's Avatar
The powerband is alot different from the 264's. The 264's were mostly low end and mid range to where the 272's are mid range and top end. I honestly don't feel like I've lost any low end at all. It does seem a little laggier though in first gear, but after that it's power everywhere. My car seems like it just wants to keep pulling. I'm trying to work out a deal on a TME so when or if I get that I'm gonna want to be tuned again.
I'd like to see 350 whp and 350 trq (I'll take more) with these cams and at least a 10.5 hotside if I don't get the TME. Al or anyone else, you think that is possible?
Old Feb 4, 2006 | 09:40 PM
yellowgsr's Avatar
Tme it's good,or just get the new ix 20g for some real gains.
Old Feb 4, 2006 | 10:44 PM
Corey's Avatar
I'd like the EVO 9 20G, but I'm gonna have to wait on that. I'm getting a good deal on a TME so I figured I'd go ahead and get it. I'm all about some deals. My car was built on deals.....
Old Feb 7, 2006 | 02:00 PM
KevinB's Avatar
Thats an under statement
