DynoFlash [Visit Site]
Case Study # 149 - Member T-Rex stock IX turbo on evo 8
Old Feb 6, 2006 | 01:59 PM
DynoFlash's Avatar
Guys - this car is amazing
This guy bought the used stock IX turbo from the 512 TQ Evo IX 2.3 L
This memeber has the following mods
Buschur intake only - stock rubber black pipe
Buschur 3 " full TB exhuast
Hks 272 cams
Stock fmic pipes
TX fmic
Forge MBC
Forge RS BOV
680 injectors and walbro pump
This was our dual stage pump gas flash with 28 psi peak on race gas mix
Attached Thumbnails Case Study # 149 - Member T-Rex stock IX turbo on evo 8-ix420.jpg
Old Feb 6, 2006 | 02:02 PM
lilman8403's Avatar
this was from a evo ix turbo? does it bolt right up to the x evo 8?
Old Feb 6, 2006 | 02:03 PM
Rollaway's Avatar
Sick Torque
Old Feb 6, 2006 | 02:36 PM
EVO8_PR's Avatar
I have the same question...
Old Feb 6, 2006 | 02:40 PM
BoostWhore's Avatar
im pretty sure u would need whats supplied from buschurs kit or oem parts from a 9 like coolant and oil lines and the outlet pipe
Old Feb 6, 2006 | 02:41 PM
ray3328's Avatar
As long as you have the black oulet pipe from the turbo it'll bolt right up. I should be getting mine put on in the next couple of weeks.
Old Feb 6, 2006 | 02:43 PM
ray3328's Avatar
Yeah you need the coolant and oil lines but the outlet pipe Buschur sells is only for their IC.
Old Feb 6, 2006 | 02:58 PM
EVIL_EVO_VIII's Avatar
Damn! Torque is sick!! It looks like the Evo IX turbo is that good after all and it seems its 95% repsonsible for the gains on the IX Evo!! Hey Al was this an 05 VIII?
Old Feb 6, 2006 | 02:59 PM
use2vtec's Avatar
Awesome torque!! As far as horsepower I would think that a stock EVO 8 turbo could make that. As for the torque that really is amzing what the 9 turbo can do!!
Old Feb 6, 2006 | 03:12 PM
DaWorstPlaya's Avatar
Hey Al, any chance you guys have a before dyno pull?
+1 to EVIL EVO VIII said
Old Feb 6, 2006 | 03:18 PM
nitz's Avatar
what were the numbers on pump?
Old Feb 6, 2006 | 03:19 PM
+1
Old Feb 6, 2006 | 03:22 PM
95GSXtoEVO8's Avatar
The max torque is very impressive.
But why does the hp level off and taper at ~4800 though? I realize this is a factory turbo, so I expect that to happen at some point, but from your other case studies on that dyno, it usually doesn't happen until after 6k with a stock turbo.
If you were racing this car, it looks like you would have to shift at 5.5k or less, otherwise you're losing significant power. It seems like kind of waste on a car that can rev to ~7000 stock IMO.
I'm sure all that torque feels awesome on the street though.
Old Feb 6, 2006 | 05:57 PM
DynoFlash's Avatar
This car was having some ignition problems at higher boost, its a medium mileage 03 and may need coils or spark plugs - this is why the car is loosing some power at 6,000
Also - the stock lower fmic and upper fmic pipes are hardly ideal
Its tough to draw generalizations about a turbo from one or two customer cars
However, I see in this turbo that the TQ pulls over 350 from 3500 to 5500 which is very broad
There is no doubt that the IX turbo is a great upgrade
However, the IX 20 G is an even better upgrade and from a perspective of sheer economics it would make no sense to buy a IX turbo - the IX 20G from Buschur is the same price or chaper if you upgrade your current turbo
The main point why this "case study" is of intesrest is that we see that the IX turbo spools VERY well on a 2003 evo without any MIVEC
I think it is safe to conclude that 05 of the power gains on a IX come from the turbo - for what it is worth
I drove this car on the road and it feels more like a IX than a 8 - the TQ on a IX is much flatter and holds longer - less of a spiking feeling than on the 8's
Old Feb 6, 2006 | 05:58 PM
scorke's Avatar
What turbo is going on the car this came off of, and how much tq do you think it will lose?
Scorke
