good AFR number(WOT,idle,cruising) ?
AL,
Wanted to know what are good AFR reading for 20.5 psi with 93 oct. i am running a little rich so wanted to adjust them. what are good number for
1. 3rd gear WOT
2. 4rd gear WOT
3. idle
4. cruising at 60-65mph.
please provide a range, others are welcome to pitch in as well.
Thanks
1. 3rd gear WOT
2. 4rd gear WOT
3. idle
Thanks
at WOT you generally want to be in the low 11's. Around 11.3-11.4
at idle... 14.5-7 is pretty good
at cruise... you can take it to about 14.7-15.0 (should give you good gas milage)
14.7 is standard for closed loop operation. The ECU automatically and constantly tries to achieve this at all times when not at WOT, so you don't need to mess with it. At WOT on 93oct with only 20.5psi peak, you can do 11.5-11.7 all day. 11.3-11.4 is fine, too.
Also of note, is when you first start a cold car it will run really rich* untill it warms up. You can usually tell when it gets warm because it'll switch closed loop mode and run ~14.7.
* corrected... I originally wrote "lean"... Jim_Paterson corrected me.
Originally Posted by AutoXer
Also of note, is when you first start a cold car it will run really lean untill it warms up. You can usually tell when it gets warm because it'll switch closed loop mode and run ~14.7.
Originally Posted by Jim_Patterson
It runs rich when you start a cold car.
A cold motor needs more fuel to help it go kaboomey.
Originally Posted by Iceman2011
i wanted to be on the safe side that is why i am at 20.5, but is 22 pretty safe with around 11.3-11.4 WOT.
22psi and 11.3-11.4 AFR on 93oct is no problem USUALLY, but every car is different.
Yeah, man, tons of us run 21-22psi all the time as long as it's on 93oct. 11.3-11.4 AFR is still conservative. Our optimum area is up around 12, but it's too dangerous to tune that close to the edge, so Al usually keeps AFRs in the 11.1-11.3 range so that customers are safe in almost any conditions and even with a bad batch of gas.
Originally Posted by lukytry
Does that mean with a TTM I can run 22psi with 93? the ttm is tunes for 93
It depends on what you were tuned for. When you send in your ECU, you told Al what psi you were running, and that is the PSI you should continue to run.
I didnt tell him any specific psi, but i figured since the ecu runs rich, and im running higher oct 93 i could up the boost a bit. I think Al tunes for 19 as a standard?
