DynoFlash [Visit Site]
Are head studs needed with meth?
Old Mar 8, 2006 | 02:27 AM
damianhindley's Avatar
Are head studs needed to run meth? and does Al only tune so high on stock bolts? I dont want to change them unly it will effect how far Al can tune my car.
Also witht his is anyone running stock headstuds with meth? thanks
Old Mar 8, 2006 | 02:30 AM
smokedmustang's Avatar
Anytime you increase boost over stock limit, increases the cylinder temps, and can cause the stock headstuds to stretch with more stresses. I would do it, cheap insurance to blowing a head gasket!!!! One of my first mods!
Old Mar 8, 2006 | 08:16 AM
Warrtalon's Avatar
I would recommend studs with alky and high boost. I got my alky done before cams, then got tuned for 26psi, but Al made sure to mention that I should get studs ASAP. I knew cams were on the way, so I wanted to wait for that installation, but I wouldn't recommend it. When we did the cams, we saw signs of possible head warping, so I would avoid doing alky without studs if I were you.
Old Mar 8, 2006 | 10:11 AM
DynoFlash's Avatar
Yes - head studs are a MUST over 320 whp
Old Mar 8, 2006 | 10:13 AM
MitsuEvoIIX's Avatar
Al whats your take on installing the headstuds in the one at a time method?
Old Mar 8, 2006 | 10:36 AM
I guess thats like wiping your butt before you take a dump. Serves NO purpose. change them all at once! Or maybe I don't get the question.
Old Mar 8, 2006 | 10:57 AM
Ev0ikon's Avatar
haha..
I'll be captain obvious for a day.
He means that the method is to open the valve cover. Take one head stud out. Replace that one with a uber ARP unit. Torque it down right. Then move on to the next stud. One at a time.
This method works for me.
Old Mar 8, 2006 | 11:23 AM
Originally Posted by Ev0ikon
haha..
you got where I "got" that joke! I guess I mis-understood the question.
Old Mar 8, 2006 | 11:58 AM
gotevo?'s Avatar
i was told it's not good to do them one at a time, because the head is warped a little due to the heat and pressure, when you release that it's a very good idea to take it all off, get it resurfaced and then put it back on all together to make sure it fits just fine.
Old Mar 8, 2006 | 12:08 PM
Warrtalon's Avatar
Well, gotevo, everyone does the one at a time method, but if you want to go through all that trouble, then that's on you. It is the preferred method, yes, but the cost, time, and trouble is quite prohibitive. Doing one-at-a-time allows you to not warp the head.
Old Mar 8, 2006 | 01:07 PM
Girlie's Avatar
So would studs be recomended for IX stage 1 cars, being that most are putting out that kind of power from stage 1 alone?
Girlie
