DynoFlash [Visit Site]
DynoFlash I need your help
Old Apr 24, 2006 | 05:15 AM
Chris@Precision's Avatar
I know you are the man to go to about tuning. My car needs to be tuned and you might have heard about it under the Precision Dyno Tuning Threads. I have learned finally that you are the one to go to.
Old Apr 24, 2006 | 09:58 AM
DynoFlash's Avatar
Anytime bro - just call me - 203-515-4110 and I will take care of you at no charge
Al
Old Apr 24, 2006 | 10:09 AM
thank you very much Al!! I tried calling and left you a message and I would like to talk to you.. Im no longer affiliated with Precison Dyno Tuning for obvious reasons (or I would be there, think about it) I am not going to bash, I dont need 2. The truth will come out in other ways. Many people know me from coming to the shop, dont believe the lies someone maybe telling you. Everyone knows the truth but people continue to be a puppet. I wouldnt want anyone to be in the situation that I am in...
Think about what I am saying. I was Precision with someone, our business
NOW IM NOT!!!!
Old Apr 24, 2006 | 10:33 AM
DynoFlash's Avatar
Hopefully you can recover your car it was sad hearing your story - best of luck !
Old Apr 26, 2006 | 05:29 AM
Thank you very much Al hope to see you soon!!!
Old Apr 26, 2006 | 06:42 AM
DynoFlash's Avatar
As soon as you have the car rebuilt and ready to run let me know !
Old Apr 27, 2006 | 07:11 AM
I will, but I have a question Al. I know the answer to this but have to ask you. You know the balance shaft that runs through the block and the pulley connects to the crank by a little belt. WELL!!! I was led to believe that I had a stubby balance shaft and didnt need the little belt to connect to the crank, because the shaft ( it is short and doesnt need to spin, therefor no need for a belt) GUESS WHAT!! It had a full length balance shaft in there and NO BELT connecting it to the CRANK.. CAN I GET YOU KNOWLEGDE ON THIS SUBJECT....
Old Apr 27, 2006 | 08:42 AM
DynoFlash's Avatar
Seems like a half assed way to proceed
The proper method is to remove that shaft 100% and remove and spin the bearings on that shaft 90 degress to stop oil flow into that shaft
Then a block off plate is put on the front cover to close the hole
The other shaft - the one riding on the timing belt directly is the one behind the oil pump - that one you install a stubby shaft and also turn rthe bearings 90 degrees
Buschur Racing is your socurce for the parts to do a proper balance shaft removal
Best of luck sorry to hear you have even more troubles
Old Apr 27, 2006 | 08:46 AM
EvoDan2004's Avatar
what is the reason for doing this anyway. and is it 100% safe on a stock motor. meening bolt on mods with stock block.
evoate ya
14
Oct 29, 2008 06:21 PM
Chris@Precision
May 1, 2006 03:32 PM
Nick@Precision
32
Oct 26, 2005 04:32 PM
timzcat
Oct 20, 2005 08:23 PM
