DynoFlash [Visit Site]
Dynoflash Tuning Trip - Chicago - May 27/28
Old May 19, 2006 | 01:55 AM
  #61
5k6's Avatar
5k6
get a pump for $76 =) lol and get tuned im installing mine next week
Old May 19, 2006 | 02:08 AM
  #62
spdrcr456's Avatar
yea nice thought but just dropped a grand for tint and alarm and will be putting in a turbo back, bov, and mbc sat morning. so going to wait a little before spending more money or else i will be gettin devorced soon. hey u going to be at the meet on sat. if so see you then.
Old May 19, 2006 | 07:06 AM
  #63
Creamo3's Avatar
Has the location been deterined as to where we will be meeting up w/ Al?
Old May 19, 2006 | 07:28 AM
  #64
vanisher's Avatar
That's a very good point..
Old May 19, 2006 | 05:27 PM
  #65
DynoFlash's Avatar
I will be posting the location by the end of the weekend
looking forward to seeing you all
Old May 19, 2006 | 05:39 PM
  #66
Warrtalon's Avatar
Originally Posted by 5k6
Im not in luck I have a IX but he can still do it using the mbc right? or should I just wait for it to come out for the ix and stay with the 93 for my first tune? Would it be more beneficial to spend more time on the 93 tune since I will be running that most of the time. My car has yet to be to the track (maby this summer) and im still on my stock cluch?
Um, well, no, the MBC has nothing to do with the ECU. You can still get the dual stage flash, but that will just consist of 100% tuning on pump gas, but then you will have an inherent map switch that is triggered by raising the boost - that's where the MBC comes into play. The downside is it's not a custom tuned race gas map, but it is at least better than nothing.
When the IX EcuFlash software is released, then you can go from there.
Old May 19, 2006 | 08:38 PM
  #67
5k6's Avatar
5k6
So Warr then I just bring my car with 93 to get tuned and if I run 100 after the tune then I just turn the boost up right? so I don't I need the 100 the day of the tune becuase its built-in to the tune?
Old May 19, 2006 | 09:40 PM
  #68
Warrtalon's Avatar
Yes, you won't need to bring race gas. If you ever run 100oct after the tune, just raise the boost to 24-25psi, but don't go crazy.
Old May 19, 2006 | 10:20 PM
  #69
5k6's Avatar
5k6
lol Warr I won't.
Old May 20, 2006 | 07:33 AM
  #70
cfdfireman1's Avatar
Warrtalon
Is this an option for a dual stage flash or 2 maps? I'd like to be able to turn off the meth and run race gas with reduced boost if I do a road race. I'm running the 20g-9 5 blade from Buschur at about 28 psi tapering to 24 at redline on pump gas now.
Old May 20, 2006 | 07:51 AM
  #71
Warrtalon's Avatar
Is what an option? Please clarify. If you have a IX, the EcuFlash map switching is not an option. If you have an VIII, then you get to use it.
Btw, why would you turn off the meth when road racing? It cools the intake charge, so it's perfect for road racing. My temps are much lower with the meth flowing on the road course. I also add race gas (100-104oct), and lower the boost some, so that I have a large safety margin.
What, you run 28psi on pump gas? Are you insane? Or did you mean with alky? We don't refer to running alky as being on pump gas.
Old May 20, 2006 | 08:22 AM
  #72
insane
Why yes I am insane, thanks for asking. 28 psi is with the meth but the problem with running it in a road race with the setup I have now is the run time from 1 gallon of meth. I could still run it but at a lower rate with less boost. And yes it is an EVO VIII. Two maps loaded with ECUFLASH or a dual flash?
  #73
WannaRace's Avatar
Warr sent you a PM couple days ago...Receive it?
Old May 20, 2006 | 08:26 AM
  #74
Warrtalon's Avatar
WannaRace, I received it and forwarded to Al, but he's busy right now. Don't worry about it - we'll take care of it.
Fireman, no that's not a dual stage flash. The dual stage flash is the regular, old method of tuning for pump gas, but then having a built-in secondary map that is triggered by raising boost.
The thing YOU will get is a 100% custom tuned map for whatever setup you want - pump only, pump + meth, race + meth, stock, valet, whatever. You will be able to switch maps whenever you want as long as you have a laptop with WinXP, the $90 Tactrix.com cable, and the free openecu.org software.
1 gallon of meth shouldn't be a problem. I road race with my SMC progressive kit that only holds 1 gallon, and I barely used half a gallon in a full 25-min session while running around 24psi. I turned it down to 24 instead of 26 for safety reasons. If you do the same, you shouldn't have a problem running out of meth unless you're using a 15lph nozzle and activating it before 20psi. Mine only starts at 18psi and goes 100% at 26psi, so I don't guzzle alky.
Old May 20, 2006 | 08:55 AM
  #75
ok
There in lies my question. You run 1 map and just lower boost and add race gas?
you posted
"You're all in luck. With the new invention of the EcuFlash software along with the Tactrix cable, you can now get as many maps as you want, and Al is offering to give customers both a pump gas and race gas tune at no extra charge. You just have to buy the $90 cable from Tactrix.com, then have a laptop with the free software from openecu.org. Then, you can switch back and forth between pump, race, valet, stock, etc., whenever you want."
Would it better to have a second map for a road race setup? I have the software, laptop with XP and the cable should be in my hands in a few days.
