Dynoflash trip to Las Vegas
Originally Posted by SiCKlEyWiKeD
Make sure you have the car boost leak tested with 25 psi
What is the altitude in LV ?
I have been starting to really put some patterns together with various tunes for various altitudes
The barometric comensation on the evo is not very accurate
It seems that 91 with 2200 feet and hot air is not a prescription for mega power
I am hoping that at least one guy headed to the dyno has a SAFC at this time ?
Originally Posted by 702RSevo
alex and manny are both using Safc but only want base flash
JUST TO CARIFY
Their SAFC must have been "professioanlly" tuned by TT to apply for this ofer
Originally Posted by DynoFlash
I would like to see at least one of them on the dyno with a A - B test and if they pay for the dyno I will upgrade them to a full custom tune at no extra cost
Also when you bring fuel to the dyno shop. Please have it in a jug with a working vent and when putting it in the cars tank, it does not leak. Would appreciate that.
Another note. Did some pressure checks tonight on some EVO's. They had leaks. Damn did they leak. Haven't tested a car yet that didn't have atleast one leak. Still looking for that perfect car.
AL you make a valid point. The police officer asked the flash guy to take him out in the car and do a datalog after they were done on the dyno. Very ironic if you ask me. The car needed a 1 degree change to avoid knock. That could very well be the degree that saves the engine on the road course.
Everyone face it. The left coast is just plain screwed when it comes to gas. Come on, 91 of any brand is a joke. Sure miss the 93 Shell of Texas. Damn that stuff was good.
"last weekend in AZ the mustang dyno there was not even loading cars close enough to realize full boost on the dyno - totally useless for accurate tuning"
I met the guy you are talking about from Tucson at the Mustang factory last winter. They really got some problems if the dyno is not loading the car. Sounds like a wiring problem for the eddy current or the torque link is way out of range. I can load a car down so much on my dyno the car will barely turn the drums. Boost on the street to the dyno seems to be with most cars, either spot on or 1 psi different. Most of the turbo cars build boost at an incline equal to or there abouts with the torque curve.
I pressure tested last week and didn't get a leak until I got to 26psi, which was when my MBC started letting out the pressure, since that's where my boost is set. That's how it should be.
