DynoFlash [Visit Site]
Question for Al!
Old Jul 17, 2006 | 09:29 PM
phenem's Avatar
Question for Al!
Al,
I have gotten a couple of flashes from you (through Buschur), so I guess they would be called Buschur Flashes. What I am doing is putting the stock ECU/turbo/injectors back in my car now. I just got a 2.3 stroker/gt35r setup and I am going to break in the motor on the stock ecu/injectors/turbo. Currently the car has a reflashed map that was for 680cc injectors, 264 cams, and 20g-9-5 turbo. I want it to be exactley like stock. What can I do?
Can I pull the current map off the car (I have ECUFlash and EVOScan) and email it to you and you look at it to know what version ECU I have and email me back a stock map with the correct Immobilzer code?
I am planning on breaking the motor in like that and then driving it up to you at Buschur's shop to have it tuned.
Thanks,
Zach
Old Jul 17, 2006 | 09:42 PM
Warrtalon's Avatar
Yes, pull your current map, email it to Al, then he will set it to stock if that's what you want.
Old Jul 17, 2006 | 09:45 PM
phenem's Avatar
Thank you, I emailed him multiple times and I know he is a busy guy. I just wanted to get an answer because we are planning on starting the car next week and I want it started on the stock map.
Thanks Warr!
~Zach
