DynoFlash [Visit Site]
quick q regarding reflash
Old Jul 27, 2006 | 05:22 PM
jojipoji's Avatar
I had a stock reflash done to my 05 gsr. Since then I added a high flow cat and drop in k&n filter. I am not going to add a mbc and keep the boost at 21. do i need a reflash again? Thanks war or al.
Old Jul 27, 2006 | 05:24 PM
jojipoji's Avatar
i mean i am going to add a mbc
Old Jul 27, 2006 | 06:02 PM
Warrtalon's Avatar
No, not really, but why are you adding a hi-flow cat to a stock exhaust? That will do absolutely nothing - you can spend that $200+ better elsewhere.
Old Jul 27, 2006 | 10:02 PM
jojipoji's Avatar
I was under the impression that a high flow cat will free up the exhaust a small bit. Another quick question, I just installed a boost guage and it says my boost maxes around 21 and tapers off to about 16. I got the flash that supposed to get rid of the boost taper. Does dropping off to 16 sound correct?
Old Jul 27, 2006 | 11:50 PM
tony_b's Avatar
Nope. the taper won't stop until you install the MBC.
Old Jul 27, 2006 | 11:52 PM
DynoFlash's Avatar
What clay said
Old Jul 28, 2006 | 09:03 AM
whitey4d's Avatar
Boost will still taper with a MBC just not as bad. U need a EBC with a stepper motor or a high load WG to eliminate taper.
Old Jul 28, 2006 | 09:29 AM
Warrtalon's Avatar
The stock turbo is going to always taper, because it can't flow as much at high rpm, so don't try to eliminate it completely with an EBC. However, reducing taper as much as possible is desirable, so get an MBC.
Yes, a HFC will SLIGHTLY increase flow, but we're talking less than 5whp. It's still a cat, so it's still very restrictive. Plus, you still have to send that exhaust through a restrictive cat-back.
GsrEviluTionX
Dec 24, 2011 07:30 PM
hkopenep074714
Oct 7, 2008 02:47 AM
edison
Northwest Region
17
Dec 11, 2007 05:09 PM
lancerMRguy
10
Aug 15, 2007 01:56 PM
Lancerguy'03
Lancer Engine Tech
11
Sep 8, 2005 02:23 PM
