anyone dyno their IX with a baseflash?
Originally Posted by daisaw1219
On my stock IX i didnt notice any power increase after a flash. I would think its easy to notice 30whp or 40 whp. I only noticed a diffrence after a mbc install set to 20psi.
Originally Posted by *sam*
Is a fuel pump needed with a base flash, MBC, TBE? And what PSI is the MBC is set at?
Tony (thought this was common knowledge)
Originally Posted by SiCKlEyWiKeD
As far as back pressure not needed. You do need a lil. Especially if it's stock turbo and you're not running a high hp big turbo car. Everyone knows back pressure creates tq. Just to prove it go dyno your car with a stock dp and aftermarket. Just my .02 from my experience.
Not sure why peeps don't get that all the backpressure you could ever "need" is in the turbo. Heck, turbo design is just as or more involved than engine design.
Turbos are pressure differential devices, your engine is a convenient heat pump to create a "waterfall" of sorts via heat. The bigger the pressure differential the quicker the turbo is going to build boost (as in 40psi on compression and 0-3psi on exit - it's like physics 101, where's the pressure going to go?), the quicker a turbo builds boost the more torque/power you have.
People get their butt dynos confused... It like it when peeps believe the whole BP on a turbo thing - I'll let em read my license plate
GST Motorsports
Aug 4, 2023 04:34 PM
JestrTuning
Southeast Region
286
Jun 5, 2008 06:11 AM
