DynoFlash [Visit Site]
anyone dyno their IX with a baseflash?
Old Aug 1, 2006 | 09:49 PM
emagdnim8's Avatar
Just curious what #'s people are seeing on their ix's with a baseflash.
Old Aug 1, 2006 | 09:57 PM
Warrtalon's Avatar
We had 2 in DC get a base flash + MBC and went from ~250whp to ~300whp. It was a local Mustang dyno, but the 250 base means it reads closer to a Dynojet. Regardless, the difference was 40-50whp depending on the pull. They did both install MBCs along with the base flash, though.
Old Aug 1, 2006 | 10:13 PM
emagdnim8's Avatar
Warr, were the cars completely stock other than the mbc? If so, what would you expect with a baseflash + mbc + catback+testpipe?
Old Aug 1, 2006 | 10:24 PM
freshevo8's Avatar
around 330whp. i'm not warr, just know from the warr/buschur package.
Old Aug 1, 2006 | 10:26 PM
emagdnim8's Avatar
I don't have a downpipe though
Old Aug 1, 2006 | 10:41 PM
Warrtalon's Avatar
DP doesn't really make power, but it does help with spool. Any reason you got a cat-back and test pipe without a downpipe? It's usually all bought at once. The mods you have are basically my WT package anyway...
Yes, they only had an MBC with the base flash.
Old Aug 2, 2006 | 05:54 PM
emagdnim8's Avatar
I got just a catback and testpipe because i found good deals for them in the used for sale section. Once I get my mbc, I will essentially have your evo IX package for a little over half the price.
Old Aug 2, 2006 | 06:12 PM
Warrtalon's Avatar
Yeah, not a bad way to go as long as the used parts are still high quality. You still need to get a downpipe, you'll need a gauge to go higher than 21.75psi (stock gauge, and then the flash itself is not a special Buschur flash without the package. It's still a good route to take on a budget (yours, that is).
Old Aug 2, 2006 | 06:15 PM
emagdnim8's Avatar
way to put me down
Old Aug 2, 2006 | 07:18 PM
EVO9GRL's Avatar
I had a mail-in base flash from Al and I dynoed my evo April 18 and I got 304/304 with 91oct. At that time I didn't have the LICP nor the HyperSun ignition. I will be taking it back to the dyno soon to see how it does now with the new mods.
Old Aug 2, 2006 | 10:44 PM
Swirvin's Avatar
As soon as I get mine (10 days and counting), I'll post up dyno and track numbers as compared to my stock numbers; Looking forward to it.
Old Aug 2, 2006 | 10:58 PM
emagdnim8's Avatar
thank you sir
Old Aug 3, 2006 | 03:18 AM
cij911's Avatar
~50 + gain
Look in my signature....or previous threads
Baslined around 250 and posted ~300 whp afterwards with just flash and MBC....Nothing else....
Old Aug 3, 2006 | 07:01 AM
EVOGOD21's Avatar
look at my signature, also dyno it with c-16 race gas and got 347whp and 340 max torque I think was 23 psi.
Old Aug 3, 2006 | 07:28 AM
nj1266's Avatar
On a turbo car any backpressure causes power loss. The most ideal way to run is w/o any exhaust after the turbo. That will give you the most power. But we cannot do that on the street. So the biggest diameter dp/cat-back/tp you can fit under your car will be the one that will give you the most power on a turbo car.
The stock dp is a restriction that causes backpressure which costs you power. That is why people switch them with larger diameter ones. To say that a dp does not make power is incorrect. Anything that causes backpressure on a turbo car costs power. The stock dp is one of them. A bigger diameter dp creates less back pressure, so it will make more power.
