Al or Warrtalon, do I need a reflash if I install an O2 housing?
Hey Al, I had a custom road tune from you in AK. I have a downpipe, tbe, & intake on my IX MR. I was wondering if installing a 3 inch O2 housing requires a retune. Will it affect my tune negatively if I don't reflash it or will it be ok to istall without another custom tune? Thanks...
Bump for a good question.
I was wondering the same. I am thinking about adding a Megan manifold, and an o2 housing. I already have your flash as well AL. it Effin' rocks by the way.
I was in the same boat. The answer I got was no, I didn't need an adjustment for the O2 housing I installed or for the new LICP I put in as well.
I do for the 255 fuel pump though... So the pump is on hold at the moment.
you should be able to install the fuel pump without a reflash. (i'm going by what warr and al told me about mine)
as for the o2 housing, i dont think you need to worry about a reflash for that either.
Need? No, it won't throw off your tune or cause any safety concern?
Good for getting the most power gains? Yes, without a retune, you probably won't get all the power from the o2 that you could get otherwise.
If you have a custom tune, don't sweat it. If you only have a base flash, then consider doing a reflash for $100 or an e-flash, but the bottom line is a reflash is not necessary.
Greg, for you, it's more important, because you're changing 2 mods, one of which is more major than an o2 housing. The combined effect of the header/o2 is very nice, but it needs a tune to be optimized.
Ahh!! Gotcha!
Well then... looks like i know what I need to do within the next few weeks.
Ok, well... update!!!
I got some HKS Cams. I put them in Yesterday. 280/280. They kick ***. I'm gonna obviously need a re flash for these puppies, so... looks like i need to save for that Manifold and o2 Housing pronto!!!
Now im all giddy!!
Now im all giddy!!
