DynoFlash [Visit Site]
2-step rev limiter quit working on mail-in flash??
Old Sep 13, 2006 | 06:24 AM
okevolutionVIII's Avatar
I haven't been using it too much lately, but my 2-step only holds for a second and then it shoots to the 8000 rpm rev limiter, which I'm not too happy about doing with the 280 cams w/o an upgraded valvetrain. I'm not letting off the clutch and the gas is on the floor in 1st gear just like it needs to be. What I'm trying to say is that it doesn't work right. All I have done since the flash is 280 cams and throttle body shaft seals which made the 2-step hold 12-13 psi instead of the 7 psi it used to hold. Anyone else have this problem?
Old Sep 13, 2006 | 07:30 AM
anjapower's Avatar
you must be rolling forward slightly. you have to be at a DEAD stop for the 2 step to activate. it won't just "quit working."
Old Sep 13, 2006 | 07:31 AM
ibanez_926's Avatar
yea that isnt really possible unless your ecu was reflashed again
Old Sep 13, 2006 | 07:46 AM
That honestly might be the problem, I think I may be rolling backwards. I'll give it a try the next time I drive.
Old Sep 13, 2006 | 09:41 AM
DynoFlash's Avatar
The factory two step is not MSD drag racing quality
The must be 100% stopped issue can be bothersome
I am working to find that parametere in the stock hex file and raise it up a bit - I have no time frame on these type of projects as its very tedious and takes load of time
Old Sep 13, 2006 | 09:55 AM
I've never had any problems with it at the track. I've just never been to the track with the Dynoflash tuned for the set up I'm running.
Old Sep 14, 2006 | 08:45 PM
EvoMike's Avatar
Veteran: Air Force
So okevolutionVIII, have you gone out and pulled the E-Brake and floored it at a stop yet to see if it was a rolling issue?!? Curious to see what the problem was.
Old Sep 15, 2006 | 08:30 AM
No, I have not got around to it yet, but I am positive thats the problem.
Old Sep 19, 2006 | 02:42 PM
sandm's Avatar
it was my issue as well. found out about the dead stop issue and haven't had an issue with it yet
