DynoFlash [Visit Site]
how much whp should i get with .......?
Old Sep 26, 2006 | 12:58 PM
yesevo's Avatar
how much whp can i expect from 3''TBE (no cat), INTAKE, FUEL PUMP AND TUNE ON EVO9 ? BOOSTING ABOUT 21PSI OR SO...LIKE STOCK...
I WANT VERY VERY SAFE TUNE...
THANKS IN ADVANCE
Old Sep 26, 2006 | 01:30 PM
saiyanzzrage's Avatar
21psi isnt like stock
id say 330whp or so
Old Sep 26, 2006 | 02:18 PM
DynoFlash's Avatar
THANKS IN ADVANCE
Stock IX's with just the Dyno Flash (with ecu controlled boost and revised boost pils) make just under or at 300 / 300 on our Dyno
A Stage I or II evo IX should be at 330 - 350 whp depending on the fuel used
My fastest customer went 11.56 in the 1/4 mile on a IX - Buschur Stage II with a pump gas tune and 110 octane in the tank
There are at least a dozen Dyno Flash customers going 12.1 - 11.56 with IX's and Stage I and II
Al
Old Sep 27, 2006 | 05:35 AM
yesevo's Avatar
i would like to get no more than 330whp....yep 330whp is what i m looking at ,.,.
whats your mods suggestion on evo9?
like i said, my evo is daily driven...and i want super safe tune.......can it be done al?
i m sure i m getting greddy sp-2 cat back soon...and maybe down pipe with using stock cat....
but not sure about fuel pump and test pipe...
help me out to reach 330whp safe way!
Old Sep 27, 2006 | 05:50 AM
Ang Wen Yan's Avatar
EVO 9 can run 24psi of boost on 93 due to revised head cooling passage,smarter ECU and better knock sensor.21psi is too low.
Old Sep 27, 2006 | 09:35 AM
yesevo's Avatar
Help///
Old Sep 27, 2006 | 01:42 PM
EVOIX2NV's Avatar
is this true?? just wondering how come most tuners only set the boost around 21-22psi on pump?? thanks
Old Sep 28, 2006 | 01:14 AM
21psi is for EVO 8.Most of the tuner set to 24psi now.Make a few search.
Old Sep 28, 2006 | 01:16 AM
bboypuertoroc's Avatar
Veteran: Army
Get the mods in my sig, you'll be good.
Old Sep 28, 2006 | 01:24 AM
fromWRXtoEVO's Avatar
It is very true. We had our Evo 9 peaking 25psi on the dyno on 91oct (turned the MBC up so that I could get higher dyno numbers) . Typically I run at least 23psi peak with no problems on 91oct and altitude(3100ft). We had peaked up to 31psi on the Evo 9 when mixed with a few gallons of 110oct.
Definately Dynoflash guaranties you a very safe tune. The car has 11k miles and is one year old and has never gave us any issues.
Evo 9 has 3"tb, Buschur cone,Forged/unos MBC, Buschur LICP and Dynoflash mail -in.
Carlos
Old Sep 28, 2006 | 01:07 PM
EVOIX2NV's Avatar
Thumbs up
good to know.. thanks everyone =)
