DynoFlash [Visit Site]
Need a fix for 91 octane on a 93 octane flash.
Old Oct 6, 2006 | 12:56 AM
okevolutionVIII's Avatar
The only gas station with 93 octane in my area quit selling it and went to 91 octane. Now my car really runs like crap, I've tried reducing the boost and adding fuel through the AFC but I guess that is raising the timing. Honestly the flash helped the knocking problem on my car and it ran better but never eliminated it. What is the best thing to do for now??
Old Oct 6, 2006 | 01:19 PM
Bump
Old Oct 6, 2006 | 01:31 PM
DynoFlash's Avatar
do you have a cutsom tune or a base flash?
Old Oct 7, 2006 | 01:59 PM
It was a mail-in flash for my mods.
Old Oct 7, 2006 | 04:43 PM
badhabit90's Avatar
add one gallon of toluene to 10 gallons of 91. it raises it to 92.5 oct. it can be found at your local Ace Hardware store.
Old Oct 7, 2006 | 04:46 PM
Ralph's Avatar
You also need to add a capful of ATF to the mix.. don't forget that.
Old Oct 7, 2006 | 04:48 PM
Ralph's Avatar
Also, sell that S-AFC and buy the tactrix cable for ECUFlash/Evoscan.. learn to adjust your tune on your own . You'll enjoy the fact that you can monitor your knocksums and timing .. also.
Just a suggestion
Old Oct 7, 2006 | 05:02 PM
badhabit90's Avatar
Cool
welp, that might help, but i think that if he has enough gas already, then he shouldnt have a problem. you could also use Marvel Mystery Oil too. I firmly believe in that stuff. it is a great top end lube and it is safe for fuel also.
so good point to add some erl to the mix.
Old Oct 8, 2006 | 06:21 PM
How much does a gal. toluene cost?? I will also be using the SAFC in my 240sx again pretty soon.
Old Oct 8, 2006 | 07:11 PM
badhabit90's Avatar
usually $5-$10 bucks a gallon. check your local hardware store. you can also use Xylene. its about the same cost.
Old Oct 10, 2006 | 05:03 AM
I dont know about this, it could get expensive as I drive about 65 miles everyday and like I said, it still had knock with 93 octane and even lower boost that it was tuned for. It has to be timing as it had a solid 10.8 AFR until 7000rpm and then ran around 11.1 to 11.3 from 7000-7800rpm in 4th gear.
Old Oct 11, 2006 | 08:26 AM
Chino1's Avatar
does ATF play as a lubricant
Old Oct 11, 2006 | 12:23 PM
inco9nito99's Avatar
Yes..toulene is very corrosive to the pump/lines/motor. ATF acts like a lubricant, yes.
Old Oct 11, 2006 | 11:17 PM
SlowCar's Avatar
Originally Posted by inco9nito99
Yes..toulene is very corrosive ...................
Old Oct 12, 2006 | 05:09 AM
Well, I didnt plan on using it. I guess the best thing to do for now is get my WI working again, the pressure sensor failed a while back.
mikemike396
Jul 7, 2010 02:40 PM
80210
10
Jun 28, 2007 06:20 PM
CrazyIvan1978
Northeast Region
15
May 8, 2007 06:24 AM
JRbmx16
Apr 20, 2006 10:12 AM
TwoMix9900
Feb 25, 2004 11:35 AM
