DynoFlash [Visit Site]
Tund by Al
Old Dec 11, 2006 | 01:54 PM
Kee1pride's Avatar
Originally Posted by DynoFlash
"theres no point in emailing you and trying to work something out" . . .
In running a business I can only provide normal customer support - if there is a problem I provide free tech assistance to help resolve. If there is a problem with my tuning, (which in my experience has been rare - example one DC trip where my wideband apparently was mis-reading), I re-tune the car for free or do what ever else I can in my powers to correct the situation
With the reflash mapping, the tuning is pretty much set and when things start to change it is usually a mechanical issue of some sort as Clay has suggested the boost and Tq curves do not look right.
I can not read minds and know if you have a problem if you do not communicate that to me so I can take measures to resolve it
Thanks
Al
https://www.evolutionm.net/forums/sh...=204240&page=2
since then no black smoke has come out of my exhaust (or at least no one has noted so) but the bits of unburnt fuel no longer come out.
anyhow i did communicate to you that the car was no faster than it previously was.
Old Dec 11, 2006 | 02:00 PM
Kee1pride's Avatar
Kevin, my point is that just showing this AFR doesn't mean your tune is bad. Did you think that by seeing this curve that it was making your car slow? I don't know how you came to that conclusion. Yes, the tune may not be optimum for whatever reason, but I don't know how you deduce that the tune is the only culprit or that it's even a culprit at all. I don't see any evidence of the tune causing a 30whp loss - do you? I'm still curious about your boost anomaly - can you explain that? I've never seen such a boost profile on an MBC.
If you look closely at the torque curve, it appears the problem is down low, because your torque is TERRIBLY low for those mods and Al's tuning. Such things are usually related to boost, and there seems to be a boost anomaly as previously mentioned. The tune may also not be good, but there's no direct indicator that the tune is the main or only problem.
yes i thought that. most other dyno's of everyone elses car's i see have relatively flat afr's around 11.2-11.3 across the board while mine is bouncing off the wall. that's very upsetting to me. dunno whats up with the boost. whats so weird about it? i've never read a boost graph before. just afr and hp/tq curves mostly. honestly i dont even know what i'm looking at as far as the boost graph.
Old Dec 11, 2006 | 02:09 PM
DynoFlash's Avatar
Originally Posted by Kee1pride
AMS turboback w/ testpipe
FORGE MBC and BOV
HKS RS intake
LPI upper and lower intercooler piping
Helix o2 housing
Maxford exhaust manifold
GSC 272/272 camshafts
GRE FMIC
edit: forgot Walbro 255 fuel pump and arp headstuds
Please Email me the map that is in your car to
Alfriedesq@aol.com
Also any Evo Scan data logs
I will look it over closely
Your car is not running properly as Clay has suggested
When I first looked at your dyno sheet I assumed it was without cams
As Clay has correctly suggested the TQ is very low in relationship to the whp and the shape of the TQ and boost curves is not typical which MAY be related to the way the dyno is configured as I suggested in my previous post
Based upon your low trap speeds at the track I would suggest that something else is going on here
I am more than happy to help you get to the bottom of it even if that means me comming there personally to help resolve it
However, I would suggest that you consider a more constructive approach to trying to get help to resolve your problems in the future
AL
Old Dec 11, 2006 | 02:27 PM
Kee1pride's Avatar
i'll try tomorrow night. no promises as i don't have a laptop or any way to extract the data. my friend eshark can do it but it depends on his availability/weather etc.
Al there are plenty more thing's i could say as far as how you've treated me both times i've met you but i didn't. i kept it car related and did my best to show evidence of what's happened in my tune, since so many times clay has told me to stop selling you short. i respect him a lot and went along with his request, which has only further proved my "opinion"
life is how it is sometimes and i just got the short end of the stick. i did not come in here with intent to ask for a free map. however i will do my best to send you the data for your own personal inquiry in case you wondered what went wrong. if anything it's a learning experience you'll grow from.
best wishes
Old Dec 11, 2006 | 02:49 PM
DynoFlash's Avatar
best wishes
My main concern frankly is in finding out what is wrong with your car be it the tune or what ever and correcting the situation
You may feel like you have the short end of the stick at this point . . . but with my experience and knowledge I would like to assist you to turn things about so not only does your car run faster but maybe you can feel like you have a bit longer end of the stick in the end
I will go through my records and try and locate the last map that was in your car
However, as I have requested, the best route is to send me your map that is in the car so I can look it over and see if any of the problem you are having is related to the tuning that is in there
Finally, I would like to know if you can pull the spark plugs after a long pull and send me a digital photo
This may sound over simplistic - but have you lined up the cam timing marks - including the front balance shaft recently ?
Al
Old Dec 11, 2006 | 04:57 PM
mdog's Avatar
Al
You're being way to nice man. I guess that's why I don't run a tuning business. By now I'd let the dude spend more $ getting tuned by someone else when looking at the graph's he posted up it looks like something on the mechanical side of things is more a miss then the tune. When I pick up an Evo Al will be the one getting me a base flash if for nothing else the way he responds to jackass posts that will accomplish nothing, especially when you haven't even had the chance to see if you can help determine the problem, then fix it.
Old Dec 11, 2006 | 05:13 PM
Az3ar's Avatar
I am not sure if that was mentioned before or not but usually the sniffer all the way back in the muffler reads a half to a full point off. So if thats true in your case you are about 11 AFR.
Just thought I would bring that up.
Old Dec 11, 2006 | 06:59 PM
DynoFlash's Avatar
In most cases I shoot for a 11.3 - 11.1 a/f up top and I also measure mine in the tail pipe
I am now using a similar DD dyno and I have seen it read funny if the long sniffer pipe is cocked in the back end at an odd angle
In the case of this car running 110 MPH in the 1/4 - that is a bit on the slow side for what I would expect with these mods and also the TQ numbers are too low
on the positive side - it looks like its very repeatable and consisant from run to run and DD dynos read a bit on the low side so it may be only down 20 whp or so
Again, I take a lot of pride in what I do and I am ready to help any of my customers who may be experiencing technical frustrations
I have not yet encountered the car I could not sort out - but sometimes it may take a while to get to the bottom of a situation
For example the "case study" I did a few weeks ago with the backwards cam cap installed and tuned else where which needed a new head - that was not that easy to diagnose
Old Dec 12, 2006 | 06:12 AM
ibanez_926's Avatar
Looks to have a bit of timing pulled right after 4500 rpms.
Judging a/f just by the tailpipe sniffer isnt always the most accurate either. Especially if you dont know the characteristics of the dyno.
I have seen much worse dyno graphs.
Old Dec 12, 2006 | 07:12 PM
Eshark's Avatar
Al, I just emailed you kevin's map.
Old Dec 12, 2006 | 07:30 PM
DynoFlash's Avatar
I have updated and revised his map based upon what I see in his dyno sheet and returned the map via email
Please try the map I just sent and report back
AL
Old Dec 12, 2006 | 08:56 PM
C6C6CH3vo's Avatar
[quote=Kee1pride;3746955]
[quote]Is it a collective known fact that unburnt fuel can be seen as black vapor out the tail pipe? I here this alot but I just can't see how this can happen.
If your talking about the source of bumber staining then I believe thats from oil passing the PVCC valve into the tract where it might mix and burn, at least I confirmed the cause with my own car.
Anyway, your car looks like it's runnig strong to me, I'd turn the boost up a psi or two though - no spikes also, good mbc install maybe
Old Dec 13, 2006 | 10:40 PM
Kee1pride's Avatar
pm'd you, Al
Old Dec 14, 2006 | 09:49 AM
David Buschur's Avatar
The list of problems that could be wrong with this car is just rediculous. Blaming Al and making a post like this is a poor way of trying to get the car worked out, that's for sure.
Al, you are becoming too nice in your OLD SUBARU driving days! haha
Old Dec 14, 2006 | 10:17 AM
mikevoSE's Avatar
[QUOTE=Kee1pride;3746756]
Then a friend threw my map into his car,
Am i the only one that noticed this...and thinks it's wrong to share a map you didn't create yourself, regardless if it's bad or good.
