DynoFlash [Visit Site]
Attn Al: Jun 264 cams
Old Jan 26, 2007 | 05:29 PM
snakedelong's Avatar
Can you make the Jun 264 cams idle with a custom flash? If so, do I have to have the cam gears?
Old Jan 26, 2007 | 09:50 PM
DynoFlash's Avatar
The idle like kittens after I tune them - no cam gears needed - great cams
Old Jan 26, 2007 | 10:50 PM
Rcebowl's Avatar
with the stock ECU?! rocking the MAF
the reason i ask is bc ... is soo i might need to get a new set of cams =P
Old Jan 27, 2007 | 12:05 AM
I am under the assumption that when I asked if he could make the Jun 264's idle with a custom flash the only way to flash was to use the stock ecu and maf. Maybe I am wrong, so Al if you could please respond that would be great.
Old Jan 27, 2007 | 10:18 AM
Rcebowl's Avatar
hahah no dude your right... i didnt read the custom reflash it was late last night and i was tired... i read tune ::shruggs:: hahh
Old Jan 27, 2007 | 10:28 PM
Your right I originally had custom tuned flash (I think that's how I said it). I took out the tuned part so there would be no confusion.
So Al, just to clear things up. You can make these cams idle with a flash correct?
Old Jan 29, 2007 | 08:03 AM
bump for confirmation on this question.
Old Jan 29, 2007 | 09:21 AM
bluebyu36's Avatar
dude, he answered you already yes!people have much more aggresive cams then that and idle fine.
Old Jan 29, 2007 | 01:25 PM
[quote=bluebyu36;3913041]dude, he answered you already yes!people have much more aggresive cams then that and idle fine.[/quot
You obviously didn't read the whole thread or you wouldn't have put your .02 in. The most aggressive cams that I have been able to find data on with a flash tune are the hks 280's which ARE NOT as aggressive as the Jun 264's. If you can find data on a car with cams that are comparible to the Jun 264's and they are using a flash tune then by all means show me the way.
Old Feb 12, 2007 | 06:41 PM
jezefink's Avatar
i can...i just had my car relfashed by pruven performance...and i have jun cams...they are way to agressive...my car only put out 317whp...due to the agressive cam..i need to change over to a milder cam such as hks 272s....
Old Feb 18, 2007 | 05:16 PM
Soon2BEVO's Avatar
Stock turbo right
