DynoFlash [Visit Site]
Dynoflash Question
Old Apr 20, 2007 | 06:27 PM
sabastian458's Avatar
Dynoflash Question
Hey Al, This is Will. I sent the 2 2003 Evo 8 ECU's in at the same time for flashing. I have a question on my flash (EVO ECU #2). I finally have the car running and idleing on its own (cam timing issue) and I now have the injectors "clacking" really loudly. I narrowed it to the injectors by ways of the stehiscope (IDK how to spell it) and by quickly unplugging one and plugging it back in. ("clacking" noise lessened when unplugged) Are they suppose to be so loud? Also I noticed that when at idle, my timing advace is 15 degrees, when the revs are raised quickly, timing jumps to 37 degrees, is it suppose to be that high? (I am using Mitsubishi's MUT2 to pull the timing information) I am sorry if this are kinda newbie questions, but I am in uncharted territory when it comes to ECU flashing and want to get someone who knows it well. Thank you for your help.
Old Apr 20, 2007 | 08:57 PM
DynoFlash's Avatar
What kind of injectors do you have in there - if one is louder than the others that would be reason to suspect it
DynoFlash's Avatar
PS - in that case I would send them out to www.injector.com and have them tested
Al
Old Apr 20, 2007 | 09:31 PM
I have the factory ones still (I was going to go larger but you recomended that I wait untill my mods required it) It isnt just one injector but all of them. I don't remember them making the noise before the flash (I did most of the mods at the same time as the flash) The car runs great arround town. Do you think running injector cleaner through them would help?
Old Apr 20, 2007 | 09:58 PM
DynoFlash's Avatar
I have yet to see stock injectors go bad
What are your mods on the car ?
Old Apr 20, 2007 | 10:46 PM
fromWRXtoEVO's Avatar
Sebastian,
Good luck, Al will take care of you. Just a tip, try advertizing your car on 3si.org
Carlos
Old Apr 21, 2007 | 09:48 AM
HKS intake with filter,
AMS FMIC & lower intercooler piping,
red Forge Diverter valve,
ACT HD clutch & ACT street lite flywheel,
Forge polished MBC (Not installed yet, running factory solenoid)
GReddy Evo2 cat back,
Megan Racing O2 bung,
Megan Racing 3in downpipe,
Megan Racing 3ing catalytic converter delete with resonator,
Walbro 255lp fuel pump,
ARP head studs & connecting rod bolts,
SS clutch line (Not installed yet)
Motul brake and clutch fluid (not installed yet)
Short throw shifter & base bushings counter weighted shift knob,
Brian Crower 280 intake & exhaust camshafts,
Brian Crower valve springs & titanium spring retianers,
AEM True Time camshaft gears (intake -4, exhaust +4)
Ported factory exhaust manifold,
freshened engine, (New rings)
Head decked .015.
And of course I have your flash. I also noticed today when driving arround town that the car is maxing boost pressure at 15 psi, is that because your tuned for a MBC and I have not put it in or something else?
Old Apr 21, 2007 | 09:51 AM
Originally Posted by fromWRXtoEVO
Sebastian,
Carlos
I would and have tried. But the problem is that the site requires you to have all of your personal information listed in your sig before you can post in the sale section. (Even though my car is listed on a verified car sales site) Also people on there really dont appreciate the car like it sould. They believe my car is only worth 5-6k even thought it is in prestine condition.
Old Apr 23, 2007 | 09:50 AM
Hey Al, another question. Does your tune change the Baro settings or anything? I think I am onto something if not.
Old Apr 25, 2007 | 09:40 AM
My issues: extremely loud injectors, possible high timing, hard start, max PSI 12
Diag performed: pressure test- no leaks, injector cleaner, rechecking of cam/crank timing, changed fuel stations, replaced vac lines and MBC.
What else am I missing? Help from anyone would be great!
Old Apr 25, 2007 | 10:02 AM
Well, I went to injector.com and used the injector calculator. according to the formula I have too small of injectors. Using an estimated 300hp, bsfc of .6, 4 injectors, using a duty cycle of .8, I get 590.62cc's.
Old Apr 26, 2007 | 06:04 AM
Update, boosting issue solved.
Old May 4, 2007 | 12:50 PM
Update. I purchased 780cc injectors, waiting for the 27th to install (have a custom tune date then) My timing is really high still (44+ degrees in the higher rpm range) Hopefully Topspeed can tell me what is happening. I am also installing a wideband and stainless manifold next week.
93HardTopTurbo
Nov 21, 2022 01:04 AM
fireroasted
Oct 6, 2015 04:41 PM
stcguy05
Jan 21, 2009 03:32 PM
EVIL_EVO_VIII
Jan 16, 2006 05:56 AM
