DynoFlash [Visit Site]
Running rich?
Old Jul 16, 2007 | 06:27 AM
gerthiekins's Avatar
Running rich?
Last fall i went to the chicago tune meet and got the custom road tune on my car. 05 VIII, intake, tbe, forge mbc, walbro fp. FOr a while now I get alot of black smoke when at WOT. I have been told my car is running too rich is there anything I can do or get done for this?
Old Jul 16, 2007 | 06:30 AM
sharkm87's Avatar
get you a tactrix cable, log some run, pull your ecu map ..send to mellon = no more rich run w/ black smog
Old Jul 16, 2007 | 06:41 AM
hmm i may have to look into that. thanks
Old Jul 21, 2007 | 04:14 AM
Mellon Racing's Avatar
let me know when you're ready
thanks for suggesting Mellon Tuning sharkm87!
Old Jul 21, 2007 | 06:14 AM
smokedmustang's Avatar
2 things I will share with my "lifes expierence" with running rich and the Evo. Oil on the Tungsten wire in MAF sensor (Spray MAF cleaner on wire, re-check), or Front O2 went bad. Plug in Autozone code checker, or at dealership. If these are OK, tune it.
Old Jul 21, 2007 | 09:26 AM
Thegame's Avatar
That's interesting. My only question is how do you get that oil residue on the MAF??? The MAF is before the recirculated valve cover vent tube. I have also been running rich. Even with a catch can, I get that oily residue on my turbo, lower intake, etc. I never really thought that the MAF was in danger because it's before the recirc tube.
Old Jul 21, 2007 | 09:28 AM
The prior "Cone intake" I bought new, had oil in/on it. If you use a drop in, or cone, which you "oil", that is how it gets on the wire. If you use the MAF cleaner, it might solve the problem.
Old Jul 21, 2007 | 09:59 AM
Thegame's Avatar
Oh okay, i got ya
Old Jul 23, 2007 | 08:15 AM
i forgot to mention i am running test pipe no cat as well.
Old Jul 23, 2007 | 09:17 AM
AndyBandy's Avatar
that black smoke you see is expected without a catalytic converter. I mean if it looks like a smoke screen, something is wrong, but if it looks like a faint haze, its expected.
put a cat on and see if you are still having problems.
Old Jul 23, 2007 | 10:40 AM
DynoFlash's Avatar
FYI - we / I do not diagnose a rich condition by black smoke or exhuast color
The only way to check the a/f is with a wideband 02 sensor
Al
