DynoFlash [Visit Site]
check engine light
Old Dec 28, 2007 | 05:05 PM
blueshark's Avatar
check engine light
hi al,
My check engine light is on and all i can think of is that i have been driving the car in the snow and real wet and icy weather. A few times the bottom of the car scraped against the snow when i was pulling into my driveway since the car is lowered. The light is on constantly for like 3 days now. I also heard some popping noises coming from the back when i hit the gas after 4th or 5th gear. But the car is driving just fine. Any idea what the problem could be?
Thanks. Omid.
happy holidays.
Old Dec 28, 2007 | 06:41 PM
ray3328's Avatar
get a code reader...
Old Dec 28, 2007 | 07:16 PM
eponti's Avatar
+1
Import Junky's Avatar
+2
Old Dec 29, 2007 | 08:36 AM
OGC's Avatar
OGC
That's funny; I have the exact same story. driving in snow, gettin' a li'l...........then my "service engine soon" light comes on. If this happens take it to a Mitsu' dealership, or a tune shop that you trust. It might be a glitch, or a serious problem. You don't wanna drive around an' just see what happens. I'm taking mine in today. I'll re-post when I sort out the problem. But my advice is have someone QUALIFIED take a look at it. ........."Code reader" ? can you elaborate?
Old Dec 29, 2007 | 09:04 AM
rcheung's Avatar
Originally Posted by blueshark
hi al,
Thanks. Omid.
happy holidays.
Were all guessing here until you get the code scanned. If it did happen when you scraped the bottom you might have damaged you secondary O2 sensor depending on what exahust you have and how you have the sensor mounted.
Old Dec 29, 2007 | 09:05 AM
rcheung's Avatar
A code reader is a scanner that plugs into the diagnostic port of the car and connects to the ECU to determine what fault is causing the check engine light to go off.
Old Dec 30, 2007 | 05:39 AM
artur's Avatar
Hi! I got same problem, my engine light is on but sometimes it goes off, when i connet to evoscan2.0 it says that o2 sensor voltage is low or knock sensor faulty,.
but it says that is reading only evo 4 fault codes, do u know if it is any software on the market which reads evo 8 fault codes? thank you
Old Dec 31, 2007 | 01:56 PM
DynoFlash's Avatar
pep boys and autozone scan codes for free
Al
Old Dec 31, 2007 | 03:11 PM
OGC's Avatar
OGC
So, I never gotta chance to take my car in.....But, I was driving up a hill, in 5th gear, kinda bogged it so I had to double clutch. It seemed to have turned the light off. (?) WTF!? Did I somehow "fix" the problem? I dunno Blushark, try boggin' your car in 5th, double clutch it and see what happens. Pfffft, I doubt it REALLY helped though.
Old Dec 31, 2007 | 03:32 PM
markymark1082's Avatar
Al
Advanced Auto Parts does it too.
Old Jan 1, 2008 | 06:04 PM
blueshark's Avatar
Ok i finally had my friend use the code scanner and it read O2 sensor and high voltage! He cleared the code for now and it has been one day and no more check engine light. could it be the cold weather since i drove it in the snow and real wet roads?? i dont know but if the light comes back i will try replacing the secondary O2 sensor. That is it for now.
thanks for all your comments.
Old Jan 2, 2008 | 08:03 AM
rcheung's Avatar
I had the o2 sensor code a while back and cleared it. It never came back either. I had it again 6 months later , cleared it and it came back the next day. That was when I had to change my front sensor and that solved the issue. If the code stays off you're fine.
Old Jan 2, 2008 | 08:34 AM
Clutchdc5's Avatar
p0300 ftl
Old Jan 2, 2008 | 11:08 AM
blueshark's Avatar
ok thanks man.
