DynoFlash [Visit Site]
Total HKS set up with reflash 310 whp no cams !
Old Feb 19, 2004 | 09:33 AM
EvoJimbo's Avatar
Hi AL, I have all the HKS setup, plus your custom flash. How much can I get this new flash for. Will this flash work with my cat delete? Forgot to mention that I have a fuel pump.
Old Feb 19, 2004 | 10:14 AM
DynoFlash's Avatar
Sure man - you will only make MORE power with the cat delete - this guy also had the pump
I tell you what - If you want to pay for an hour of dyno time I will give you a custom reflash for free - just call me to set up a date and time - I realy perfer to set the tuen for the car - we can just install the upgrade but it may or may not work as well as your current custom flash - with a little fine tuning you will see big numbers
You should make the same power or even closer to 315 b/c of the cat delete pipe
Old Feb 19, 2004 | 10:28 AM
EvoJimbo's Avatar
Thanx for the reply Al, I reflash it once I get my cams and fuel injectors I'll give you a ring. What do u recommnend, injectors or a Fuel Pressure regulator?
Old Feb 19, 2004 | 10:29 AM
DynoFlash's Avatar
Denso 660's
Please keep in mind my offer is only for your current set up
Cams and injectors require a compelet retune!
Old Feb 20, 2004 | 12:55 AM
DA-Evo's Avatar
dynoflash: when are you guys coming to so cal?
Old Feb 20, 2004 | 11:06 PM
fhall168's Avatar
i work on cars but never a turbo .what is (ebc)
Old Feb 20, 2004 | 11:09 PM
blonde's Avatar
EBC= electronic boost controller
