DynoFlash [Visit Site]
My Evo is drowning!
Old Mar 5, 2004 | 03:34 PM
DynoFlash's Avatar
Originally posted by GottaGoFaster
I was originally Flashed in October with an AEM intake and Buschur Muffler Delete pipe. I have since added a Hallman MBC and will be adding the Buschur 2.5" Downpipe and Walboro 255...I will be getting retuned the 20th at Agile...I guess my map with the fuel pump will be used for future people with the same mods?
NO - the through the mail tunes ALl must go through testing on at least 5 seperate evos before we release them and they all are detuned at least 5 - 10 whp
Old Mar 5, 2004 | 05:10 PM
Dale_K's Avatar
Originally posted by ob4
Hi Guys,
I have one question about the fuel pump. Isn't the fuel regulator suppose to dump the excess fuel back to the tank? So is it true that even the upgrade fuel pump is increasing the fuel pressure on the fuel line, but the fuel rail will always see the same pressure because we are still using the same fuel pressure regulator? I am thinking about getting the pump too...so I would like to hear what you guys think.
Thx,
ob4
Took the words out of my mouth. If the regulator is working right, how can it run richer?
Old Mar 5, 2004 | 06:08 PM
DynoFlash's Avatar
The regulator is a set size orfice - it is not "closed loop" fuel pressure control
Its a small cheap piece that opens and closes a valve according to boost pressure
When the boost pressure rises the hole gets smaller and rises the fuel pressure higher also
When you put a bigger fuel pump on the fuel pressure rises SLIGHTLY higher than the stock pump under high boost long pulls and the car runs slightly richer
Notice - SLIGHTLY richer
Old Mar 5, 2004 | 06:50 PM
camdog17's Avatar
Damn! I had to read this entire thread three times in order to understand what's going on...*did I say that out loud?*
Anyhew...ok, Al...in my case - I'm going to hold off until the 20th. I'm gonna baby my evo until then...I'm going to SC this coming Friday (was supposed to 'run' a few folks, but that's out)...my question is this...
Do I go ahead and install the Boost Controller (Hallman Pro RX mbc) this weekend? What effects will this have on my current 'limbo' situation? I'd like to have this mbc installed by the time you grace my Evo with your knowledge and skills...
Old Mar 5, 2004 | 07:05 PM
DynoFlash's Avatar
Go ahead get it in and keep it down at like 19 psi and you'll be fine - just dont beat the heck out of the car - drive easy !
Old Mar 5, 2004 | 09:04 PM
TURBODAWG's Avatar
The car will run perfectly fine at cruise and at light throttle. Anything on my car above 3 or 4 psi will cause the air fuel to go full rich. If you have the Walbro, just drive it easy and you will be fine. One good hard run after the car is fuel tuned properly and the plugs should clean up nicely.
Brian
Old Mar 5, 2004 | 09:30 PM
DynoFlash's Avatar
Brian
Agreed
We have a multi speed fuel pump controller - the pump does not see full voltage on part gas and cruise - ONLY when you get on the boost good thats when it really starts pumping out the fuel
Old Mar 12, 2004 | 10:12 AM
twan's Avatar
Ok i understand whats goin on here.
My question to AL is when does he see the need for a new pump in the modification process.
For example: BR 3" Full TB + HKS EVC + Flash
Would this setup require a new pump? If no, then what thrown into the mix would dictate the addition of a pump?
Old Mar 12, 2004 | 11:35 AM
SinCityEvo's Avatar
Al will definitely recommend a pump with those mods. Actually, he is now recommending the pump with any mods. Do a search and you will see why the stock pump may not provide the proper flow under load conditions.
itsmeek
Feb 9, 2016 02:50 PM
Strider1048
10
May 26, 2013 11:00 AM
OG
12
Apr 19, 2013 05:39 PM
kyracer1989
Dec 31, 2012 12:43 PM
black_beauty
55
Oct 31, 2010 08:29 PM
