DynoFlash [Visit Site]
# 3 most active poster and rising !
Old Mar 9, 2004 | 07:51 PM
DynoFlash's Avatar
If you add up my posts under Alfriedesq and Dynoflash - I have the # 3 most posts on the forum and both of those names are in the top 15
https://www.evolutionm.net/forums/me...ers&perpage=25
Sorry - my car is at the shop and i have nothing better to do tonight but lurk around the evo m forums
Old Mar 9, 2004 | 07:56 PM
MalibuJack's Avatar
Woah.. I'm up there too.. BTW you still gonna do the UTEC tuning?
Old Mar 9, 2004 | 08:11 PM
DynoFlash's Avatar
Yes I am tuning it - I di one already - very easy t learn if you did the WRX utec
Its a great unit - vastly suerior to other piggy back solutiuons
Its good if you want to be able to play around yourself - it works very well
We are also selling the Uflash for $79.99 whoch works in conjucntion with the UTEC to remove the fuel limiter, rev limit and smooth out the fuel curves for easier tuning
Its a nice product - however there is no performance advantage over a reflash, the sole advantage is the tunability which can be a blessing or a curse
The only bad thing I have found is that the ign timing control requires you to default to UTEC knock control which IMHO can be a dangerous thing compared to the uncanny stock knock sensor
Agsin in certain applications control ove the factory knock may be desired - however - IMHO - I would prefer to leave the facstory ecu knock protection function FULLY intact and operational. We are able to get very decent results and smooth power with that knock function 100% in full force. IMHO - its going to be hard to 2nd guess on the knock retard settings that they have on the stock ecu
Old Mar 9, 2004 | 08:27 PM
MalibuJack's Avatar
Thats the plan.. If it wasn't for the frequency that i change things around, and make adjustments, I would have to say the DynoFlash would have been my preferred choice.. I've already changed my configuration 3 times in the past year requiring completely different tuning..
Old Mar 9, 2004 | 09:42 PM
DynoFlash's Avatar
IMHO - the best possible set up would be a custom Dyno Flash running the day to day pump gas operation and the UTEC tuned with a c-16 race gas map ready to dial in at the turn of a switch
A slightly lower cost senario would be the through the mail flash - fine adjusted with the UTEC - but with the Dyno flash ignition control, mainating the stock knock operation, on pump gas - - and then a wild C-16 race map on the utec for the track
Sure its a bit more costly - but you would get all the reliability, smoothness and protection of the stock ecu and also the ability to get max performance at the turn of a switch
Us evo guys are very lucky as there are many ecu tuning options availble right off the bat - where as with my WRX there was very limited tuning options for well over the first year
With only limited evo numbers in the usa - soon there will be more ecu options than cars!!!!!
UTEC is one of my favorites - but it is geared towards a more "hands on" owner who is embarking on an educational path to discover how to tune the car - - that can be a lot of fun or a real nightmare depending on your perference
