DynoFlash [Visit Site]
ARP Head Studs & Main Studs...
Old Mar 18, 2004 | 11:41 AM
zupber4930's Avatar
Hey AL....I'm prepping for the meet on the 26th...had a question for ya...
I know you recomend that we replace the head studs with ARP's. I just bought them...but I also bought the Main Bolts as well. Do you recomend replacing them as well or is it not necessary right now till I go with a bigger turbo and start pumping out a lot more ponies?
ALSO...what psi should I set my MBC for a flash from you using the following mods...
3" AMS Turbo Back
MBC
K&N Style Cone Filter
HKS 264i/272e cams
Walbro 255lph pump
Thanks Al...
Old Mar 18, 2004 | 12:49 PM
DynoFlash's Avatar
Re: ARP Head Studs & Main Studs...
3" AMS Turbo Back
MBC
HKS 264i/272e cams
Walbro 255lph pump
Thanks Al...
I would suggest you let martin at AMS handle the studs
Boost i want is 21 or 20.5 peak - falling to 19.5 at 6,000 and then going a bit lower or staying at 19.5
Old Mar 18, 2004 | 12:50 PM
zupber4930's Avatar
Ok...thanks....but do you recomend having the main studs....or is it over kill?
