DynoFlash [Visit Site]
buschur intake vs k&n drop in filter
Old May 7, 2004 | 01:32 AM
BushBurninEvo's Avatar
is there a big difference going from the k&n drop in filter to the br intake?
will i need a reflash?
Old May 18, 2004 | 09:42 AM
newevo8's Avatar
Talking
ttt great question!
Old May 18, 2004 | 10:05 AM
fury656's Avatar
The additional turbulance caused by any Cone Filter will throw off the MAF sensor signals, in most cases causing the car to run lean across the middle. Therefore a tuner must account for these miscalculations by adding fuel at these lean spots so yes, you would need a different flash unless you have access to an S-AFC. My advice would be to stay with the K&N filter, much simpler overall and comparable enough power wise.
Old May 18, 2004 | 10:12 AM
Zeus's Avatar
I'd like to hear from Al on this one too. Of course it will make a big difference on high powered cars, but I'd like to know the difference on 300whp or so cars.
Old May 18, 2004 | 07:54 PM
DynoFlash's Avatar
Very interestingly - just TODAY we had a guy in who previosuly was tuned 10 days ago with a 3" exhuast, fuel pump, boost controller and HKS RS intake kit with 305 ft lbs and 304 whp
he did not care for the HKS sound when the stock bov was venting - you can hear it very loudly in comparsion to the stock one
So he took off the HKS and re-installed his stock air box and K & N filter
Today I retuned his car - all other mods same and same boost point as before
HE LOST 10 whp after 5500 rpms and 1 ft lbs of trq
Up to 5500 the power band was the same
This result is typical of what I would expect
THE HKS RS and the Buschur intake kit yield just about the same results on the dyno
Old May 18, 2004 | 08:58 PM
Zeus's Avatar
...was there a dyno before the retune?
