Record 351 ft lbs on a mustang dyno - exhuast, intake and mbc with Dyno Flash
Originally Posted by raced_EvoVIII
Would it be better to say your car weighs a little more on the mustang dyno or less when entering it in on the computer to figure out the resistence.
In this case it seems as if the dyno was being used at a dyno day with other evos and the people there would have enjoyed seeing a bad result on my car - instead I hear it was one of the strongest examples they have seen on the dyno
As for the exact ways you can manipulate numbers on a mustang dyno - I know nothing about that subject
Originally Posted by DynoFlash
Eat your heart out !
https://www.evolutionm.net/forums/sh...937#post968937
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by kevo
how come the hp is so low compare to the torque? Also seems like the power don't hold in high rpm. To be honest, the graph don't look good at all.
Originally Posted by limey
I'm confused Al...according to this thread it looks like the dyno has been manipulated a lot and does not really give you cause for celebration does it?
Originally Posted by robertrinaustin
This car rocks. I'm pretty sure it put down more torque than any EVO ever on this dyno, and that includes a pretty big turbo EVO. His hp is higher than any stock cam EVO on this dyno.
You're mistaken. Al wasn't even there. No manipulation involved.
I think what Limey was referring to was this statement by Shiv about the above Dyno Sheet...
Originally Posted by shiv@vishnu
Hey Super Tuner,
I hope your trying to be tricky. If not, you've just proven yourself to be not very observant or knowledgable when it comes to dynos. See that dyno plot you posted? Yep, that one.
The RPMs are off. Probably because a wrong gearing/rpm factor was input. Why else would an EVO make nearly peak power at 4700rpm.
Torque is calculated by the mustang dyno by computing HP (work done which is independant of RPM) and calculated RPM. With the calculated RPM reading lower than it really is, Torque will be artificially inflated by the same % as the RPM error. See?
Thanks for playing the "Look At How Great I Am!" game
You just lost.
genius.
Shiv
You just lost.
genius.Shiv
Guys,
Al wasn't even there. There may be a mistake in the setup, but I doubt it. I'll see what info I can get from the shop. They regularly host dyno days and I have yet to see a Vishnu tuned car match this one. The Vishnu tuned cars were stage 1 (I think) and were actually run on a colder day (about 20 degrees) with less humidity last fall and were around 265 hp and trq.
This car my be an anomolly, but it runs like a beast.
Robert
Robert
Who cares anyway ?
The customer is happy and his car is fast - and its lasted for a long time with my tune with no advserse consiqeunce - thats all that matters !
No Al....My point was not that you manipulated the numbers, but that the numbers were manipulated and you are choosing to ignore this fact and are continuing to brag about results that are obviously very wrong
For a 4G63 to create the characteristics seen in this graph it would need more than a simple "Dynoflash"....these curves are more suited to an american big cubed V8 than a 2.0 ltr 4 cylinder, and I am sure a Dynoflash does not change the entire volumetric efficiency of an engine
"who cares anyway?"....your customers should care that you would not think this was a little strange, and because of this I would think you would care...
Stock EVOs normally put down 210-220 for hp and trq on this dyno.
I'm not sure why this car made the trq it did. Was it Al's tuning or is this some EVO freak?
I too dyno'd on a MD AWD Dyno, but had very different results.
Mods were: Intake, TB Exhaust, 264/272, Walbro pump, DynoFlash, and SAFC II. 93/94 Octane, 22psi dropping down to 18 at redline. Pull was done in 4th gear, imput weight was around 3450.
262.5HP @ 6700RPM
254.3TQ @ 3700RPM
I went to the track a couple days later and ran:
12.27@111.40MPH w/1.74 60'
12.34@111.40MPH w/1.84 60'
12.45@111.11MPH w/1.88 60'
Im no super driver, but it was hooking up fairly well and I didn't miss a single shift.
I guess what Im trying to say is, let's see what this car runs. Without the BS of "my clutch... I missed 2nd... Im new to this" the numbers should tell the story.
I makes me think of one of my favorite jokes... "What does a 400HP and a 1000HP Supra have in common?" - 11 second timeslips!
Im not saying Al has a bad product - he doesn't, his dynoflashes are AWESOME. I just think something might have been overlooked and these graphs may need a tad more "inspection".
262.5HP @ 6700RPM
254.3TQ @ 3700RPM
Funny, I don't remember seeing you there that day. Just to clear things up for all the "experts". This was the only car that day that put down any where near this much torque. There were 2 WRXs, an STi and 3 EVOs that dynoed. This car wasn't the first or last and nothing was changed in between. The owner of the shop drove it after the dyno run and said it pulled like a beast.
I have tried seeing your point of view,but I couln't get my head that far up my ***....
I guess the case of the torque monster is solved then.... you must be right, just reading your posts indicates to me that I am well out of my league as far as interlect and knowledge is concerned... my only hope is that one day my car will perform like a "Dynoflash" car
Believe me... Al's torque is no phantom. As you can see from my #s below, my torque is also "suspiciously" high compared to my HP, but it's for real. The car pulls like a big block from a stop. Nobody believes my car is a 2L 4Cyl... When you can spin all 4 grippy Advans with 2 skeptical V8 drivers in the car from a launch, you know you've got the TQ.
Basically, other than for the initial tune, I say screw the dyno #s anyway... what matters to me is being able to pull on basically anyone at anytime.
