DynoFlash & Missfire
Originally Posted by MSanad
ha ha don't rub it in,
so al u suggest going back to the stock plugs? or stick with what i have or try the 8's?
I your more of a person who likes to tinker - by all means get the 8's
BUT - you have to change them a bit more often
dynpflash is the only one i know of, plus everyone praises it so much
Also - many states do the emmissions testng on OBD-II cars through the data port so the reflash will get you through emissions
IF ANYONE has the Dyno Flash and is not getting the 0300 code fixed - IF you're not fully satisfied - just send it back for a FULL REFUND
The main point of the Dyno Flash is makingyou car run better and make more power
We can not guaratee that i will fix this code problem that some evos seem to have - although it does seem to get a bit better with the Dyno Flash
Hmm, Al, I thought you had this all fixed? https://www.evolutionm.net/forums/sh...d.php?p=723156
Edit: Posting what Al originally said, in case he edit's the original post (not sure if he can...).
Originally Posted by Alfriedesq
No need to worry - 1st of all - ALL dyno flashed cars are already fixed and dont get that code so no reason to take it back to dealer - - we already had done the R & D on that misfore code and how to fix it and ALL our reflashes have the fix already in
IF you notice NONE of our clients are the ones who are complaining about this !
Second - anyone who gets the ecu reflashed by just has to send in the ecu and I will reaload the dyno flash for FREE i have all the maps saved and backed up
Originally Posted by robi
I got rid of my code! Only took installing the AEM EMS to do it too!
SC~0300 is kicking my 455...
You know what's really weird. Last week I was getting the P0300 so bad, that everytime I was in a gear (between 2nd and 5th) between 3k and 4k RPM, it would misfire.
Then I decided to try new plugs, no dice. Then I was going to try to replace the tranny fluid, but instead I reset the ECU by pulling the negative. Then, it "went away"!
Have you experienced that SC?
THEN - we started to get a few guys who still got the codes
SO - at this point ALL I can represent is that the Dyno Flash appears to resolve the problem in SOME cars - makes it BETTER in others and in some cases does nothing
Bottom line - if anyone wants to TRY IT and if it does not fix your 0300 code - send the Dyno Flash back for a 100% refund - no questions asked - HOW is that ?
...I reset the ECU by pulling the negative. Then, it "went away"!
SC~ who saw/felt the warning 3 times on his 10 mile commute this morning.
I used to get the misfire code also, but it went away and hasn't come back in more than 3000 miles. I always coded when decelarating. I did add 2-3 degrees of timing to my idle settings and since I havent coded again.
Gil-superz
Gil-superz
