DynoFlash [Visit Site]
Which intake will make more HP?
Old Jul 7, 2004 | 02:26 PM
SSKILLA's Avatar
AEM intake
Stock intake boot with a cone filter
or
Stock boot and air box with k&n panel filter
Ive been reading up on all these maf reading problems with aftermarket intakes and i was curious to know which one of these 3 would be the best to get flashed with.....AL can you chime in on this question......??
Semper Fi
Old Jul 7, 2004 | 02:40 PM
SterlingEvo's Avatar
I have a cone-type Buschur Filter, and as far as I can tell the only "advantage" of that over the box w/k&n is you can hear the turbo spool and blow-off, which I like. Definitely if you add a higher-flow filter, you'll need to get flashed, because on an otherwise stock setup, more air flow will make the car's computer compensate and actually lower your performance.
Old Jul 7, 2004 | 04:28 PM
bishiboy's Avatar
I know the HKS Racing Suction kit WILL add some HP if tuned correctly. It increases airflow due to the body of the intake tube (cone shaped, AKA Velocity Stack, That whole Physics thing where air will flow faster thru a smaller area (Bernoulli Effect)).
Al (Dynoflash) has had some good results.
Old Jul 14, 2004 | 07:37 PM
johny719's Avatar
Hey, I know tons of people have asked questions regarding intakes and which is best, but I was planning on getting the HKS RS... is it bad a filtering? and does it really make you run lean? Doesn't running lean cause potential detonation and harm to your engine?
Old Jul 14, 2004 | 07:39 PM
jason@NTEC's Avatar
i say hks rs intake. it seems to be the most effective.
Old Jul 14, 2004 | 08:50 PM
Guack007's Avatar
I say RNR custom cold air intake with 3in piping
Old Jul 14, 2004 | 11:37 PM
Ang Wen Yan's Avatar
HKS RS is the best.HKS is a big manufecerur u know?
Old Jul 16, 2004 | 12:23 PM
Guack007's Avatar
So is mitsubishi, and they makes some of the worst cars in the world. Also my mitsu TV has some serious problems. Just cause there big doesn't mean anything.
Old Jul 16, 2004 | 12:39 PM
NOVA EVO's Avatar
HKS RS Intake...
