DynoFlash [Visit Site]
Dynoflash and P0300
Old Apr 29, 2005 | 09:19 AM
naucrx's Avatar
Originally Posted by precisi0n
i have a question along these lines... i took my car to the dealership to have the oil changed and to have a CEL checked out... the tech said it was the p0300 and he updated the computer... is your flash still working properly?
I haven't had a Dynoflash on my car since October. I intended to get it put back on when Al came to AZ last but some other things came up and I didn't get a chance to make it back over to Dustin's place.
Since October I got my ECU flashed by to try to correct the p0300, which didn't work. They ended up replacing my transmission under warranty and it has not been back since.
Old Apr 29, 2005 | 09:38 AM
precisi0n's Avatar
since i have a dynoflash on my car and they updated for the p0300, u think they screwed up my flash?
Old Apr 29, 2005 | 11:50 AM
naucrx's Avatar
I talked to the tech who worked on my car and he said that the p0300 fix shouldn't affect a flash tune. Did your car run the same after you took it in?
Old Apr 29, 2005 | 12:00 PM
precisi0n's Avatar
ya...just curious....
Old Apr 30, 2005 | 09:11 PM
precisi0n's Avatar
so Al, can i get a definititive answer in this? Since they updated for the p0300, is my tune wiped out?
Old May 1, 2005 | 12:33 AM
Corey's Avatar
I think you would know by driving the car if it was gone. Judging by you mods on your sig, you should be able to tell if your car is running different. I know my car wasn't running all that great before I had Al do a custom tune on mine.
I've had mine come on twice and both times I disconnected the battery. Ever since the second time, it hasn't come back. Only time will tell.
Old May 1, 2005 | 02:43 AM
precisi0n's Avatar
seems to be running strong still but was just wanting to know for sure....
Old May 9, 2005 | 01:59 PM
sskount's Avatar
I just got my ecu updated to fix this p0300 also by Mit. My ecu was custom tuned by Al. I'm also curious.
