DynoFlash [Visit Site]
K&n panel filter vs buschur cone filter
Old Sep 14, 2004 | 03:55 PM
BushBurninEvo's Avatar
any power difference between the two and is a reflash needed changing from the K&n to the buschur cone filter?
Old Sep 14, 2004 | 04:00 PM
feldguy's Avatar
just the sound
Old Sep 14, 2004 | 04:39 PM
DynoFlash's Avatar
The Buschur cone filter alone is god for 3 - 4 whp - with the suction tube it makes the same as the HKS RS intake kit - about 9 whp
Old Sep 14, 2004 | 05:37 PM
so no significant change in a/f ratio to need a reflash?
Old Sep 14, 2004 | 08:38 PM
SurfguruJon311's Avatar
You might run a little lean when using an open source air filter like the cone filter so I would recomend a reflash.
Old Sep 14, 2004 | 09:59 PM
DynoFlash's Avatar
The cone style air filters alter the way the mass air flow sensor reads the air flow through the intake. This causes distinctive distortions from the way the stock air box measures the air flow. A retune is needed to compensate for the cone filter.
Old Sep 14, 2004 | 10:41 PM
mitsuorder's Avatar
To be completely honest if you cherish stock like driveability I think you would be better off picking up a drop in K&N panel filter from Buschur, you kind of have to adapt you driving technique with the other choice, at least I did with my BR pipe and cone filter. Although I did see something the other day about David Buschur redesigning his pipe because of so many reports of poor idling and stalling, I'd give them a ring.
Albert Ngo
Jan 5, 2015 08:52 AM
speedypollard
24
Feb 23, 2014 02:45 PM
Gary@MellonRacing
Sep 15, 2012 12:35 PM
Renyulb28
Jul 17, 2006 02:16 AM
