DynoFlash [Visit Site]
Al, Do I need another reflash?
Old Sep 22, 2004 | 09:18 AM
platinumspecv's Avatar
Hey Al. I want to buy the HKS RS kit. I got a custom tune from you when you came to tampa. Will I need another reflash after I install this kit?
Krunal
Old Sep 22, 2004 | 09:32 AM
siantjab's Avatar
Most likely, yes. An intake will change the air flow that your MAF is interpreting. Al will be down here in Orlando in a few weeks though; you should be OK if you don't drive the car super hard until then.
Old Sep 22, 2004 | 09:35 AM
scottatyamaha's Avatar
Yes...you will. Al has a special tune for the HKS kit. Ohh and I know I am not Al
Old Sep 22, 2004 | 09:36 AM
err....i would not put that kit on until you get the tune done. You could go too lean and melt a piston.
Old Sep 22, 2004 | 11:30 AM
You shi!!Tin me!! I thought its just another intake kit - more air = more fuel. Why would I go lean. But very well. I will sign up for that Orlando tune.
Krunal
Old Sep 23, 2004 | 10:50 PM
DynoFlash's Avatar
Correct - the HKS RS intake really alters the maf reading in a very consistant and distinct pattern which results in a super lean a/f ratio in the middle of the power band
Adding that intake on a car flashed for a different intake only makes matters worse
The good new is that with our flash for the HKS RS intake the a/f winds up perfect and the HKS kit makes really great power gains !
