Evo on E85
Old May 31, 2007 | 08:46 PM
spt's Avatar
spt
Evo on E85
Check out the article: CLICK ME
Old May 31, 2007 | 08:59 PM
merkzu's Avatar
Cool, nice write up. I wonder if the burn speed of E85 was taken into consideration with the timing. What's conservative for gasoline might be aggressive for E85 if it burns faster, but I haven't seen any good info on it, just a few posts here and there without any real numbers
Old May 31, 2007 | 09:03 PM
spt's Avatar
spt
Here's a informative article on E85 burn rate compared to various octanes: CLICK ME
Old May 31, 2007 | 09:18 PM
merkzu's Avatar
guess I should have clicked around more, nice site
Old Jul 8, 2007 | 02:07 AM
bus's Avatar
bus
Just read that entire article. Lengthly, but very informative. Interesting how the ethanol did nothing noticeable after 4 months of submersion in the E85 formula. I've never ran racing gas through my car. Probably won't either seeing as how I'm selling it very soon.
Old Jul 8, 2007 | 08:39 AM
Flyin EVO 2's Avatar
General rule of thumb is start with 6 degrees less timing vs. C16 on boost then click up 1 degree at a time. From what I've been hearing from all the fast guys I know running E85 is there running around the same timing maps as 100 octane, but the cars are running a couple of more pounds of boost vs. 100 octane.
Old Jul 12, 2007 | 12:31 PM
I r teh Winnar's Avatar
Those power/torque curves are well, just that: curves. Anyone else notice this? Surely you could smooth those out. I am guessing that was just a rough tune in order to see the results of E85 vs its supposed 100 octane counterpart?
Old Jul 16, 2007 | 09:36 PM
FastLearner's Avatar
E85 Info
Hey All, If you want to talk w/ an expert on E85 check out www.englishracing.net Lucas was one of the first to tune up here in the NW (Washington) on E85. Hope this helps.
Old Jul 16, 2007 | 10:01 PM
Kc2Buk's Avatar
Great E85/Evo INFO
Old Jul 19, 2007 | 11:20 PM
CheesyEVO's Avatar
So, will an evo run better on e85? And I assume it requires a tune to do that, pls advise???
Old Jul 20, 2007 | 08:39 AM
merkzu's Avatar
Its great if you want to run more boost. Get a walbro, 1000cc injectors and a tune. Datalog the car around the seasonal blend changes. Going from winter to spring to summer youll be able to add some timing and boost and need to add some fuel. Going from summer to fall to winter youll remove some fuel, and might need to run less timing/boost. You could probably get a reasonable middle of the road tune that is richer in the winter and doesnt go nuts on the timing and be ok all year round.
Old Jul 21, 2007 | 10:05 AM
feldguy's Avatar
Considering Buschur tuned a car that normally (i think) made 435whp on their dyno, and added E85 to tank and retuned which required about 35% more fuel to get stoichiometric ratios right, but the damn thing made 535whp!
Old Aug 31, 2007 | 03:18 PM
Robdevo's Avatar
Good info there on that link. What is funny, is that here where I live we have probably 15 local cars that run E-85 full time. The reason that is funny is because it is not available here in pump form. All of us go across the border to get it.
As far as how it compares to other types of gas, I would say it is better than 110, one shop here in particular (Abel Racing) has been tuning cars on it for awhile now.
The main thing you need to consider with E-85 is the amount it takes to use it. For me, i am around 620whp and I am using 1600cc injectors, and 2 in tank walbro 255 pumps. Duty Cycle is around 80~% so I have some room left.
Old Sep 7, 2007 | 06:21 PM
s14er's Avatar
good info yo.
Old Sep 28, 2007 | 08:35 AM
saga2628's Avatar
Great Info. I'm seriously considering this.
