E85 fuel trims
Old Apr 1, 2008 | 12:41 PM
pileofparts's Avatar
E85 fuel trims
So I have been working on getting the trims closer and closer. My low is at +1.1 and my mid is -0.8. There seems to be one problem though. While idling for long periods of time, the fan kicks on, load is increased, and the injector pulse with jumps just a little bit (+2 or so)
This jump in the pulse width bumps the short trim up and then as a result the idle trim dives down -8%. After the fan stops the injector pulse width goes back to normal and the low trims out to near zero again.
My question is are other people experiencing this?
Is this within acceptable deviation or is this indicative of a larger issue?
Old Apr 1, 2008 | 02:27 PM
[EVO]Cookie's Avatar
Plus Minus 10 is fine ECU trims the car non stop.
Old Apr 1, 2008 | 02:34 PM
Alright. Just noticed other people were shooting for +/-3% on here. It doesn't seem to max out at all and AFR's look good. Just wanted to make sure that this is acceptable and expected.
Thanks for the response.
mrfred
Jan 6, 2024 09:43 PM
mrfred
Aug 14, 2023 11:03 AM
needsboost
Mar 18, 2016 08:04 PM
hkumar
11
Sep 9, 2013 07:55 PM
toxic-evo
AEM EMS
Mar 16, 2012 02:20 PM
