E85 = +60whp / +55wtq peak
Old Oct 5, 2008 | 03:41 PM
RazorLab's Avatar
Did another E85 tune the other day. Great gains on this one.
+60whp / +55wtq peak going from 91 octane to E85
An interesting trend I am seeing with E85 over the last couple of cars I have tuned with it. Pretty much every single one I put E85 in, rescale the injectors and do a first run with the same tune as on pump gas just to make sure everything is ok. They always gain approx 20-30wtq with the only change being putting E85 in and rescaling the injectors. Same tune as on pump!
This fuel just rocks. I love it.
Mods:
2006 Evo RS
FPgreen with Stock actuator
Cosworth M2 cams
ETS 3.5 FMIC
Nisei licp
Walbro fp
RC 1000cc injectors
3 " TBE no cat
Titek o2
Vibrant Open Filter
GM 3port solenoid boost control(via stock ECU)
Map switching between E85 and 91 oct (via stock ECU)
Old Oct 5, 2008 | 03:45 PM
joshesh's Avatar
I cant wait to join the E85 Army next weekend! Keep it up Bryan.
Old Oct 5, 2008 | 06:15 PM
lan_evo_mr9's Avatar
Great results! Just got mine done this weekend and I can also confirm the 20hp gain just by changing fuel. Unfortunately my car was picking up phantom knock from a bad power steering pump so the car was taking away all timing. My other problem was that the forge boost controller would only let me get 25psi. All that aside I still made 390 hp/tq with no timing and "low" boost. Sorry to get off topic but my tuner wasn't able to adjust the cold start due to my car being hot when I got there. When I attempted to start my car this afternoon, it took several tries and when it did start I had to keep my foot on the gas to keep it running. I have Ecuflash- what do I need to change?
Old Oct 14, 2008 | 08:07 PM
eitan's Avatar
Is this E85 from a regular pump or a racing fuels blend? If it's pump, our pump E85 around here is branded Verasun. Same stuff?
Old Oct 14, 2008 | 08:59 PM
RazorLab's Avatar
From the pump. Pearson fuel
http://www.pearsonfuels.com/
Old Oct 15, 2008 | 06:06 AM
PeteyTurbo's Avatar
man I didn't expect that without a change in timing. My car would be SLOW without E85 so I thank the USA for that
DisgustipatedM3
Jan 3, 2014 10:37 AM
GST Motorsports
Dec 22, 2010 12:37 PM
GST Motorsports
Mar 9, 2010 08:13 AM
GST Motorsports
Dec 23, 2009 10:43 AM
GST Motorsports
Nov 4, 2009 11:19 PM
