Filled the tank of the evo last night for $25!!!
Old Oct 15, 2008 | 09:38 AM
scheides's Avatar
EvoM Moderator
I made the plunge. I have plenty of injector, and have been meaning to try this for a long time, but I've been too busy helping other people with their stuff!
Some notes:
-Ran the car till the gas light came on on BP 92
-Left my alt-maps alone (this is my BP92/alky map which includes injector scaling, fuel, timing, and boost)
-on my base maps (normally just pump gas tune) I simply changed the injector scaling by 29% (down). Turned boost down and left timing/fuel maps alone.
-Filled car with Holiday E85 (fall blend I'm sure) for $2.19/gallon, $25.30 total for 11.5 gallons. I realize that E85 is subsidized and no I don't necessarily agree with the practices used to produce it. It's wasteful, arguably worse for the environment, etc.....but F U K it, I'm an american. We've built this nation on being wasteful and polluting! There are worse things in the world, like strippers and politicians...besides, I'm using this to kick my meth habbit.... Seriously though, I am a tinkerer, and this is an experiment for me. If we can produce this stuff for $5/gallon and be nicer on the environment and skip all the other BS, I say hell yea. I am not going to pretend for one moment that I am 'going green' by doing this. I want 105 octane at the pump, that's all
Anyways, politics aside...
-I flipped my alky kit on, which triggers my BP92/alky alt-map. WHy? Because there's gasoline left in the lines, silly! I start the car, it idles normally. I wait a few seconds, and rev the car up a bit to about 2000 rpms, and wait for the car to start to idle/run like crap. This never happens, but my fuel trims all of a sudden go way whack (I'm logging all of this). Now flip off the alt-map and drop down to my base E85 tune.
-I then drove for a while, nice and steady. (This is impossible for some people I've come to find out) and watched my fuel trims. I had it at 1008 for gasoline and started at 713 for E85...ended up raising it to 770 to bring fuel trims down to about 0%, but I still have a few gallons of gasoline in the tank (even though light was on) so I'm not gonna kill myself over this until I run the tank dry and fill up again. This is basic evo injector scaling, btw, nothing fancy.
-So now I'm roughly scaled where I want, I try going WOT and watch my wideband (this is key here, w/o this, you are gonna want to go and visit your local tuner...I highly recommend Shane @ DB Performance). My AFR's were in the high 10's, but the car feels flat.
-Turn up boost to where it was on BP92/alky map. 29psi tapering to about 23-24 at redline. Re log WOT runs, check AFR's, and proceed to dial them in.
-At this point I'm sitting thinking....the car is boosting good and AFR is nice at around 11.8:1, but it feels kinda FLAT. I contemplated it for a few moments as I checked some other stuff out, and then realized I hadn't touched timing yet So I proceeded to copy over my BP92/alky timing map to my base map section and let'er buck. Power is back, car feels awesome.
-What next? Well my goal here is to try and run more timing, and thus make more power. So I toss a few extra degrees at the car and it just takes it. Car feels AWESOME. Previously I was making 357whp and had made a best of 365whp with an extra degree or two of timing but the car would knock. Now with 3' of extra timing, the car freaking RIPS and I am PUMPED! This means two thigns:
-->E85 is an awesome fuel for boosted cars, I am able to get more power out of it than my BP92/alky map. BUT!
-->Who's to say that if I add a second alky jet to my BP92/alky tune I won't see similar results? E85 is just gas with a massive percentage of alcohol mixed in.....adding an extra alky jet (currently running a single 1.0mm/~450cc jet) would be an add a lot of octane/cooling mixture.
I'm gonna roll on E85 for a while. It's fall, I'm curious what happens when I fill up at various stations and whatnot, people always complain about their car running like **** here and there, blah blah blah. More comments to come later.
BTW, whenever I run out of E85 stations, guess what I can do? Pull up to a BP and fill up, then flip my alky kit back on, triggering my alt-map (BP92/alky) tune, then ZOOOOOM!
Thanks for reading.
Old Oct 15, 2008 | 09:45 AM
DSMorBUST's Avatar
interesting...
Old Oct 15, 2008 | 09:47 AM
PeteyTurbo's Avatar
Cool..You should be able to run alot of timing advance, I know I do..What is your max timing advance at 7000?
Old Oct 15, 2008 | 11:01 AM
scheides's Avatar
EvoM Moderator
Not sure at 7000, but my car makes peak power at about 6200. Before I could run about 14' there, and now I can run 16-17'. At 7k I'm sure that would be 18-19'
Old Oct 15, 2008 | 11:42 AM
Ph3n1x's Avatar
what size injectors and what IDC are you seeing.
Old Oct 15, 2008 | 11:51 AM
scheides's Avatar
EvoM Moderator
FIC 1050's, 75% IDC (peak)
Old Oct 15, 2008 | 11:59 AM
PeteyTurbo's Avatar
sounds like a plan..I wish e85 was as cheap over here, still 3 dollaz
Old Oct 15, 2008 | 12:01 PM
sprytsi's Avatar
interesting, i keep thinking about switching
Old Oct 15, 2008 | 12:47 PM
scheides's Avatar
EvoM Moderator
You will find the price varies all over the place, as does the ethanol/gas mixture. If you're thinking about switching, I would recommend learning how to log and tune your car yourself first, and even installing a wideband (I have a LC-1...no gauge needed, just the wideband wired into the ecu) so you can stay on top of mixture changes. Then, use tephra v5 mapswitching hack for emergency use
Old Oct 15, 2008 | 01:05 PM
Ph3n1x's Avatar
I guess we would need 1600cc injectors for a 35r.
Old Oct 15, 2008 | 01:45 PM
scheides's Avatar
EvoM Moderator
And likely a double fuel pump setup too, unless you want to just turn the boost down
Old Oct 15, 2008 | 02:04 PM
beemerfreak's Avatar
There's a few E85 stations near my house, but it's $3.00+ a gallon. How much is regular gas by you?
Old Oct 15, 2008 | 02:05 PM
Billy@EnglishRacing's Avatar
every time i pick up e85 it comes out to around $100-$150
Old Oct 15, 2008 | 02:46 PM
scheides's Avatar
EvoM Moderator
~$3.20/gallon for BP 92
Old Oct 15, 2008 | 07:27 PM
denver's Avatar
what are your mods, Im just curious about turbo, fuel set up etc?
I have been on e85 since mid summer and love it, since I converted there have been at least 2 other cars in the area make the switch. Its really awesome stuff
