Getting ready for E85, some questions...
Old Apr 9, 2009 | 06:54 PM
LV///R's Avatar
Originally Posted by nj1266
Question: If you sacle the injectors smaller, wouldn't that affect the latency? Don't you have to change the latency as well?
I'm curious as well...
Old Apr 9, 2009 | 10:45 PM
sslevo's Avatar
Originally Posted by jid2
Yes.... Scale the injectors 30% smaller in the ecuflash field called "Injector Scaling". That's it.
I would try and run 1 full tank through the car before tuning.
I'm doing the same thing soon, so i change the injector scaling 30% smaller, thus giving the car 30% more fuel, does this sound right?
Old Apr 10, 2009 | 08:36 AM
jid2's Avatar
Exactly.
You will still need to log fuel trims and make adjustments based on your findings, but 30% is a good starting point. I had to make two adjustments to the scaling to dial things in.
I would set them 30% smaller and drive around for 1 full tank. Then on the second tank start looking at your fuel trims and then make any minor adjustments.
This assumes you already have the trims balanced with the latencies, if not you'll need to do that as well.
Fast_Freddie
Oct 30, 2023 01:56 AM
mrfred
Aug 14, 2023 11:03 AM
mrfred
23
Jul 3, 2017 06:59 PM
mrfred
Apr 17, 2015 09:38 AM
Quick Reply: Getting ready for E85, some questions...
