How-To: Warm/Hot Starts (and cold ones) with E85
Old Aug 7, 2009 | 04:24 AM
  #46
travman's Avatar
Originally Posted by GST Motorsports
You sure you have that table defined correctly? It makes a change everytime I tweak with it. Putting it to zero on my personal Evo it will not want to start at all on E85.
Beats me - its the 88590015 rom, Mrfred was the one who discovered the tables so he would be able to answer that better than me.
So when you zero out your IPW map your car will not start - just cranks but no fire?
Old Aug 7, 2009 | 10:05 AM
  #47
GST Motorsports's Avatar
Yes if it's cold out and the car is cold, it will not start with that zero'd out on E85.
Warm start on E85 will start but takes longer.
Currently on my personal car, I have them dialed in on RC1000's, starts up right when you turn the key in all weather. Slight hesitation to start in 15-30F in Tahoe. Mini-battery and all.
Old Aug 7, 2009 | 04:48 PM
  #48
project_skyline's Avatar
Wait your running rc1000's or dialed in as them? Would you care to show some latency settings im just curious how they look.
Would a bigger latency on the really low voltages affect startup? Because say on PTE 1200's the 4v latency is 5 i believe and on rc1000's is 3...
Old Aug 7, 2009 | 05:32 PM
  #49
It could, log your voltage when cranking.
Yes my personal Evo is running RC1kcc's.
Old Aug 9, 2009 | 02:01 AM
  #50
It looks like its about 4-6 v's. When you say log it, do you mean before i turn the key over or while its cranking?
Also if i understand right and this only applies to warm starts. If having the pedal to the floor makes the car start faster then its because there is too much cranking fuel from a too big of cranking IPW adder and if it doesn't then the IPW adder isn't big enough.
I increased it to 14 ms for the 50-82C range and that seemed to aid in helping the car start faster with no gas.
Also here are my current latency's.
3.312
2.184
1.56
0.936
0.696
0.384
0.288
Here are the ones im thinking of trying to see if those make any difference.
5.280
0.936
0.696
0.384
0.288
Thanks for the help
Old Aug 18, 2009 | 08:44 AM
  #51
RAbishi's Avatar
Yea it sounds like you guys need to tweak the startup IPWxCoolant Temp more.
Log what your coolant temp is when you get the hard starting and tweak the corresponding cell.
Why is it that I can't find a IPWxCoolant Temp in Ecuflash?
Old Sep 6, 2009 | 10:59 AM
  #52
Routybouty's Avatar
Has anyone been logging (hot) starts? I noticed, and it doesn't always do this, my coolant temp will be around 190F, and during cranking it shoots up to 320ishF. It falls back down to 190F after it's started. Then, I'm assuming because of this, the calc load shoots up to ridiculous numbers like 400+ even 2000+ for a couple frames. This in turn makes the AFR map around 37AFR and throws 38 counts of knock for those frames.
I can post up a little log if anyone wants to see this.
My problem is warm/hot starts. Warm starts are horrible and hot starts just aren't satisfactory. I adjusted the table in this thread but the idle acted weird and I had really bad throttle hang issues. So I'm back to the stock settings for now.
I recently played for a short time the start enrichment table and it seemed to get rid of most of the crazy evoscan numbers (load/coolant temp/AFR map). It still doesn't start nearly as well as I would like. Is there a target AFR I should be trying to hit during starting?
Old Sep 9, 2009 | 08:19 AM
  #53
Yamahar1's Avatar
So has anyone found a fix? I will pay someone to help me fix it........
Old Sep 13, 2009 | 10:57 AM
  #54
Routybouty's Avatar
Old Sep 13, 2009 | 11:44 AM
  #55
My car starts just fine now after modifying the IPW for starting. If your adjusting it and nothing changes it probably isn't the right table.
Old Sep 13, 2009 | 01:05 PM
  #56
Routybouty's Avatar
I tried adding timing to the starting area and that seemed to help. Although when I logged it, it has 5 degrees of timing for a little bit and then kicks into the table. No matter the adjustment it always starts at 5 for a bit. I think a degree or 2 might help, is there a table for cranking timing?
Old Sep 13, 2009 | 01:19 PM
  #57
97TSiAWD's Avatar
Did you have to increase or decrease the IPW values to improve warm starts? And at which coolant temp ranges did the changes seem to have the most effect?
Old Sep 17, 2009 | 08:39 PM
  #58
97TSiAWD's Avatar
Bump to see what changes seem to improve warm starts. Better yet, anyone who has improved their warm starts want to post their "Cranking Enrichment IPW Adder" table?
Old Sep 18, 2009 | 11:48 AM
  #59
l2r99gst's Avatar
Posting that table won't necessarily help you, since it is dependent on the injector size and latency. But, it will give a good idea of the adjustments that you may need.
Old Sep 22, 2009 | 08:46 PM
  #60
Scooby257's Avatar
+1 for IPW settings
and any idea for the timing table?
