E85... Will it eat the stock fuel lines or not.
Old Jul 16, 2009 | 05:47 PM
  #31
TTP Engineering's Avatar
Originally Posted by barneyb
There is no fuel filter on the Evo - just a sock on the inlet to keep out the big chunks.
This.
Old Jul 16, 2009 | 05:52 PM
  #32
Originally Posted by ROGERV
I found an inline fuel filter that I will be using with my Buschur Double Pumper system.
http://www.jayracing.com/index.php?m...roducts_id=263
This is a great pump setup here with the option to use stock or AN lines.
http://ttp-engineering.com/catalog/p...roducts_id=426
We have these in stock!
Old Jul 16, 2009 | 08:57 PM
  #33
GST Motorsports's Avatar
Originally Posted by TTP Engineering
This.
There is a filter contained within the white plastic fuel assembly. It's not just the sock. Unfortunatly you have to replace the whole white plastic assembly.
Old Jul 16, 2009 | 09:13 PM
  #34
The assembly is not cheap. If for some reason you find it necessary to change out your housing, you might as well move to a twin pump setup.
Old Jul 16, 2009 | 09:35 PM
  #35
AWD Motorsports's Avatar
If anyone happens to need the housings i have a dozen of them from our salvaged cars we have sold.. 125.00 shipped..
Also We have 10 Buschur Double Pumpers in Stock.. With and without Core!!!
https://www.evolutionm.net/forums/ev...ml#post7274653
This setup is superior to the Fullblown due to the twin feed from each pump.. The fullblown with its " T " design is not as smooth flowing as a " Y " design twin feed setup.. We are able to push the Buschur units much further than the FB units during our testing..
MIke
Old Jul 16, 2009 | 09:47 PM
  #36
The point in replacing the housing was to change the filter. Changing a used housing for a used housing makes no sense.
The Fullblown twin pump kit is $399 compared to the competition's $500-525 and does not require a customer to box up and mail in their stock housing. If a customer wanted to go back to stock, they would have their stock single pump housing available in order to swap them back out and sell the twin pump setup.
Furthermore the Fullblown twin pump kit can be used with stock lines or aftermarket AN fittings.
The Fullblown twin pump kits have a purple anodizing finish that protects it from alcohol fuel corrosion.
It is a much cleaner look with both fuel pumps flow Y'd in the housing versus outside the housing with extra lines and hose barbs. If two fuel feeds combine into one, it doesn't matter whether they convene in the pump housing or a few inches down the line, they still end up in the same exact hose.
In the end it comes down to fit and finish, whether you want two hoses and a bunch of clamps and a Y fitting or not.
The customer can be the judge of quality.
Expect a review of the Full Blown setup from us shortly.
Old Jul 16, 2009 | 09:53 PM
  #37
Is the 399 price tag with pumps??? The Buschur 500.00 Tag is with 2 pumps and filter kit.. Just FYI..
The Buschur Unit is proven to 700+hp and 9.0's... I have personally used the FB and run out of fuel long before 700hp.. Yes the machined housing is prettier but from our testing does not work as well as Buschur..
Mike
Old Jul 16, 2009 | 10:03 PM
  #38
Is the $525 List Price with no core return?
Who needs a twin pump fuel system with with two walbros when there is already one in their car to start.
More things that make no sense.
I don't know anyone that wants to ship out their stock fuel pump housing so they can't go back to stock at a later time.
According to the site, there is a $150 core charge with the BR unit so its $650 compared to $484 with the 2nd pump included on a FullBlown unit to complement one's own single walbro already in the car.
$484 vs. $650 and the customer can be the judge on quality.
VS.
Old Jul 16, 2009 | 10:16 PM
  #39
Nissan2Evo's Avatar
The Buschur double pumper is the better designed and functional unit, just give it a rest.
Regardless...E85 is perfectly fine to run in your Evo with whatever pump setup you end up with..it won't chew away your lines/pumps/tanks like a pack of termites.
Old Jul 16, 2009 | 10:18 PM
  #40
Im not going to argue back and forth.. I wanted to just point out from EXPERIENCE which unit we have tested to be the better unit.. Carry on with which unit you " think " is better..
MIke
Old Jul 16, 2009 | 10:39 PM
  #41
Never said it was cheap, the point was/is, there is a OEM filter other than the sock, even if you didn't know of it.
- Bryan
Old Jul 16, 2009 | 10:41 PM
  #42
MIke
Experience? That's crazy.
Old Jul 17, 2009 | 02:04 AM
  #43
project_skyline's Avatar
On the stock fuel setup single pump where would be the best place to put an external Fuel filter?
Old Jul 17, 2009 | 09:48 AM
  #44
You would need to modify the stock fuel assembly to get rid of the OEM internal fuel filter.
Most guys end up putting the external fuel filter under the hood for ease of replacement.
Speed Element
EvoX 'For Sale' External Engine / Power
415
Jun 9, 2016 01:31 PM
evoyrrah
Sep 2, 2010 04:02 AM
Speed Element
Aug 5, 2010 11:19 AM
Speed Element
14
Mar 17, 2010 12:51 PM
Speed Element
Feb 17, 2010 12:27 PM
