View Poll Results: Your preferred E85 spark plug for EVO VIII?
NGK BR7ES
10.74%
NGK BPR7ES
23.14%
NGK BR8ES
23.14%
NGK BPR8ES
42.98%
Voters: 121. You may not vote on this poll
E85 spark plug poll
Old Aug 8, 2009 | 10:01 PM
  #46
dsevo's Avatar
Iridiums FTMFW.
BR8EIX at .024"
565 hp on stock ignition and zero issues. I'm sure they can take more.
  #47
dsevo's Avatar
Originally Posted by lan_evo_mr9
Do the 8's come with Iridiums from the factory, because the 9's do. I figured the factory usually has a fair amount of R&D that goes into this stuff. I have only changed my plugs once- when doing the E85 conversion and messing around with latencies and such. The iridiums can take a lot of abuse, boost, and so on. They are worth the price in my book.
Yes, 8's come with Iridiums too. The stock iridiums are like $15 a piece though.
Old Aug 9, 2009 | 02:11 AM
  #48
project_skyline's Avatar
Originally Posted by dsevo
Iridiums FTMFW.
BR8EIX at .024"
How much are these each and how many miles have you gotten out of them?
Old Aug 14, 2009 | 10:53 PM
  #49
CULVIIIER's Avatar
Originally Posted by Jim in Tucson
Mind you, I do have an VIII, so I may be a bit out of touch with the IX...
Are the NGK LFR6A-11 coppers the exact same dimensions as the OEM Iridiums? I didn't think there were any coppers for the IX? Or have I been asleep at the wheel...again?
Yes they are. It makes it nice. I bought 6 sets from my local Napa just to have them in the toolbox
Kent
Old Oct 10, 2009 | 03:36 PM
  #50
Jim in Tucson's Avatar
Just out of curiosity, has anyone actually tried a HOTTER than stock plug with E85?
I'm running the BPR7ES.
It appears that the same plug is available in 6, 5, 4, and 2 heat range.
Old Nov 23, 2011 | 04:19 AM
  #51
naveedlari's Avatar
Hi,
I am trying to start my car with sparktech cop non-CDI but it is not starting up i have tried 0.030 to 0.060 gap on NGK Iridium BR8EIX new plugs ..Previously i was using same setup with stock coils and HKS twin power DLI same plugs with 0.045 gap .. i am running evo VIII MR JDM, stock block, HKS272 cams, BC valve spring retainers, hks 3037 turbo, Perrin Fuel rail, 1000cc precession injectors, AMS F-1 intake manifold and S90racing throttle body 70mm... Guys please help me on this issue.
Old Nov 23, 2011 | 06:49 AM
  #52
badev0's Avatar
Since this is not on the poll, I vote NGK Iridium BPR8EIX (6.99/each at oreily's - 1 year warranty)
10,000 miles on them, over 60 passes at the strip, and hundreds of pulls on the street. E85/33lbs of boost (car traps 137-138 to get an idea of the power it makes). Car has never broken up at all with this set yet. Gapped at .022". This is with the used spoolinup COP non cdi. Standard copper plugs don't last long at all for me.
Old Nov 23, 2011 | 08:37 PM
  #53
Originally Posted by badev0
Since this is not on the poll, I vote NGK Iridium BPR8EIX (6.99/each at oreily's)
Is this considered an OEM equivalent plug? I might try a set of these. Now I'm changing copper plugs every other oil change.
Do you think the COP plays a significant role in your happiness with these plugs? I don't have a COP setup. Yet.
Old Nov 23, 2011 | 08:52 PM
  #54
thebluesky's Avatar
BPR8ES gapped to 24, running 37psi on e85.
Old Nov 29, 2011 | 07:23 AM
  #55
badev0's Avatar
I'm not sure if its equivalent to OEM for evo 9's. definitely not 8's though.
Nope, actually I ran these plugs before even getting a COP and it was perfectly fine. I bought the COP thinking it would fix my misfire issue, but the plugs did by themselves.
Old Nov 29, 2011 | 07:52 AM
  #56
10isace's Avatar
br7es @ .023"
I change them every third oil change. I'm going to try .024" today. I was using bpr8es on 91 oct @ .025" gap, but it would blow out on E85 and 27+psi.
Old Nov 29, 2011 | 06:05 PM
  #57
Good to hear. I will try a set of the NGK Iridium BPR8EIX next time.
Old Dec 5, 2011 | 02:56 AM
  #58
Levar's Avatar
Veteran: Army
I will be running the NGK BPR9EIX for my EVO8 until I am convinced otherwise.
Old Dec 5, 2011 | 05:15 PM
  #59
marcusE's Avatar
Goin to run bpr7's with a Spoolinup COP this weekend with e85 and stock turbo.. shouldn't be a problem.
Old Dec 5, 2011 | 05:20 PM
  #60
tscompusa's Avatar
i use bpr8es they usually go about 2500 miles.
reason i use copper plugs is because i like to get the reading off the plugs every now and then,
so i use a plug that makes me change them sooner then later so i have an excuse to remove them,
do a leakdown/comp test, etc..
