tuning by turbine color with E85
Old Aug 11, 2009 | 06:49 AM
94AWDcoupe's Avatar
https://www.evolutionm.net/forums/wa...ml#post7381739
first look at wheel tuned on E85. This was at 11/1 on gas WB. EGT were low in 750C range. the wideband is new so I am sure its reading correctly. I tried leaning to 12 and beyond but butt dyno felt slower. Now I am thinking it needs even more fuel. maybe 10.5 range.
Old Aug 11, 2009 | 10:01 AM
inco9nito99's Avatar
...are you a stripper? :P.
Yeah that does look a little hot. Although the general consensus is to tune by wideband, I personally like the 70-90mph test and won't go any leaner than 12.0.
Old Aug 11, 2009 | 11:27 AM
GST Motorsports's Avatar
Are you basing the color of that wheel on how much carbon you should be seeing? (from your experience with normal gasoline)
-Bryan
Old Aug 11, 2009 | 09:04 PM
mrfred's Avatar
Not sure if E85 is going to produce the same color variations as gasoline, and wouldn't the turbine color be a combination of all driving conditions?
Your experience with E85 AFR is contrary to nearly everyone else's experience. Leaner seems to be working better for nearly everyone else.
Old Aug 11, 2009 | 11:30 PM
-Bryan
btw, I'm not challenging you 94AWD, just opening up discussion.
(I'm getting sick of having to post this disclaimer, so is life)
Old Aug 12, 2009 | 06:26 AM
94AWDcoupe's Avatar
I dont have the answers. I was just making a friendly observation. I am not so sure that the 12/1 target is ideal. There are some targeting 11/1 with excellent results. This is my first run with E85. I will have better data when car goes back together.
Old Aug 12, 2009 | 10:10 AM
Yea I've tried really rich mixtures and the car just feels soft and unresponsive. I haven't seen much gains from 11.5 to 12.5 on the dyno other than trace knock cleaning up with the leaner mixture, and large difference in feel and response on the street.
In the 10's the mixture gets hard to light in my experience
Old Aug 12, 2009 | 11:18 AM
project_skyline's Avatar
11:1 has always just produced a whole lot of knock and no power. 12:1 ftw. lol
Old Aug 12, 2009 | 01:40 PM
Colt4g63's Avatar
Mid 12s FTW
Old Aug 14, 2009 | 06:29 PM
0xDEAD's Avatar
Originally Posted by Colt4g63
Mid 12s FTW
At least.........
Old Aug 14, 2009 | 06:36 PM
grillpt's Avatar
I've never ran E85 but from the pics I've seen on here it def burns a lot cleaner than normal gas. I would imagine that is just a product of being alcohol... I wouldn't be worried...
Old Aug 15, 2009 | 11:02 AM
PeteyTurbo's Avatar
In my Experience with E85, if you try to tune a car to 10.5, especially at higher airflow, you will be much more likely to get misfire, and will be more demanding of the ignition system. I have logged decent gains on a dyno leaning out from mid to low 11's by as much as 20hp with no other changes, which could also be in part to do with a more complete combustion.. I have ran cars up 13.1 on E85 with no ill effects including high EGT's, but overall power went down a bit at that mixture. My turbine wheel looks identical to yours and I do not run it very lean anymore by my standards but others may consider it a bit lean
MY 02 housing is so clean inside you can eat off of it, and the inside of my manifold has no carbon deposits for the most part, it got cleaned so well that all you see is a bit of surface rust from the iron lol
IMHO I wouldn't rely on the color of the components running E85 naerly as much as I would with gas..
Old Aug 15, 2009 | 11:08 AM
DJ Brett B's Avatar
I know running a bunch of alcohol through MY system really cleans things out... whisky $hits FTL
Old Aug 15, 2009 | 10:06 PM
03whitegsr's Avatar
Man, I have to wonder if our local blend is different then what most get or something.
Most people here have better success keeping to the low 11s on E85, 20 PSI or 45 PSI, doesn't seem to matter. Going into the 12s ends in lower power and a detonation prone tune almost every time.
Old Aug 16, 2009 | 12:03 AM
mrfred's Avatar
Sounds like its low on alcohol. Par for the course in Utah? :-) Or perhaps really crappy gasoline is used in the blend. Most places blend with 87/88 octane, but maybe they use 85 octane or something.
