E85 vs 93 oct
Old Nov 2, 2009 | 12:23 AM
flyboytb's Avatar
would it be possible to have preset maps for e-85 and 91oct for a Cobb AP?
Old Nov 2, 2009 | 06:02 AM
TK40's Avatar
There aren't any E85 pumps between LI and Manhattan, it's just the ones in LI that I'm aware of. You would have to calculate your drives and fill ups since you won't have many places to get E85.
I'm in NYC as well and recently have been seeing a lot of the TLC drivers in Yukon's with Flex Fuel logo's on the back. Next time I see one I'm going to ask where they have been filling up because those guys drive like 20k miles a year they must know some places that I don't. As soon as E85 becomes a bit more common in NYC I am definitely switching over.
Old Nov 2, 2009 | 06:03 AM
TK40's Avatar
If swapping maps is possible to run both E85 and 93 that would definitely make it easier, but I still think I will wait until more stations start carrying it.
Old Nov 2, 2009 | 08:37 AM
lowkey's Avatar
Registered User
Yes, thats the advantage of the AP, a quick < minute flash and you are on your way. But Cobb does not have OTS maps for E85, so you will have to either create your own or get one made at a tuner. I'm near the Cobb shop in Plano and they have given me a quote for tuned 93 and E85 maps.
Old Nov 2, 2009 | 08:46 AM
chriswolf81's Avatar
What are the chances of Bushur coming out with a switch for the maps, like they did for the 9?
They were reasonable and would be a great solution. What about the final drive gear from Bushur, what happened to that?
Old Nov 2, 2009 | 04:48 PM
krackerstache's Avatar
Thanks for all the great posts.
I know of the one E85 station near me its like 10 miles away (I think its a BP not sure)
But there is also a station around the corner form me that sells 100 oct race gas. But he only does fill ups with that pump and its about 850 a gallon
I think I would consider it more when they come with a map swap device because I always have my laptop on me
Old Nov 2, 2009 | 05:36 PM
seventhfactor's Avatar
I want to switch to E85 but the only station is on my way to work. I think i'm going to wait till i have done mods to the car and more stations are available.
Old Nov 4, 2009 | 07:16 AM
murlo26's Avatar
I would never map switch between the two. Even some gas left over in tank can really screw your afr's. So your more aggressive map could be fubar when running with part 93 and part E-85. No thanks, it's not really a quick switch scenario. I'd go meth if you want switchable power.
Old Nov 4, 2009 | 07:19 AM
TTP Engineering's Avatar
The key is to leave the E85 map on for 5-10 minutes after refueling with gasoline, then switching.
Old Nov 4, 2009 | 08:13 AM
doibugu2's Avatar
How many people are actually running e85 and are switching maps periodically? Has anyone run into any problems?
Old Nov 4, 2009 | 11:24 AM
EvolNinja's Avatar
Originally Posted by TTP Engineering
You cannot switch back and forth on an Evo X. Only evo 8-9 with JOT altmaps cable.
Plus if I remember it correctly, it takes about two full tanks to convert fully back so it's no use to switch back and forth. It's not good for the long haul.
Old Nov 4, 2009 | 07:16 PM
itznoraa's Avatar
Another question: does e85 kill the life of motor oil? My friend uses e85 and says the oil gets less viscose compared to 93.
Is this true?
Old Nov 4, 2009 | 11:29 PM
DirtyCookieX's Avatar
This might seem like a dumb question...
Do the shops that tune for e85 have drums filled with the fuel on location? What's the process of making the actual switch over?
Old Nov 5, 2009 | 08:30 AM
ikt's Avatar
ikt
good thread
Old Nov 5, 2009 | 10:39 AM
tipoytm's Avatar
Originally Posted by ikt
good thread
+1, I'm curious also about the conversion... I just wish the X came with at least 4 more gallons in tank capacity. Refueling every 150 miles with E85 is just not an option for a lazy guy like me.
