100 octane tune for daily driver
Old Feb 8, 2010 | 12:42 PM
number 8's Avatar
I was thinking about getting a race gas tune. Would it be possible to get the tune for 100oct., and turn down the boost to run 93 pump gas on occasion, if necessary?
Old Feb 8, 2010 | 12:53 PM
geardog75's Avatar
good question, i would assume it wouldnt hurt as long as your not into boost
Old Feb 8, 2010 | 01:11 PM
goofygrin's Avatar
it's also timing, right?
Why not tune for both and just use map switching as needed?
Old Feb 8, 2010 | 01:21 PM
number 8's Avatar
Gear, thats what I'm hoping. Goofy, thats an option, with a Cobb AP, but it would be nice if i didn't have to buy that.
Old Feb 8, 2010 | 01:27 PM
apagan01's Avatar
you have an evo 8 , your tunner should be able to switch maps and i think you use the IC sprayer switch. you cant do this on a IX, i had to flash the car on my IX back and foward to pump and race gas.
Old Feb 8, 2010 | 01:30 PM
rgar's Avatar
You don't need a cobb ap, you can get tuned and use tephra's map switching(based on the IC sprayer if you have it or a switch you can add on).
Search around for tephra map switching.
Old Feb 8, 2010 | 01:35 PM
rgar's Avatar
You can get this for a IX or an 8 I believe if you don't want to use your ICS switch.
https://secure.buschurracing.com/cat...5bd3d1a40a531c
There are instructions for how to build the switch here on the board somewhere, but I can't seem to find them right now.
Old Feb 8, 2010 | 01:40 PM
number 8's Avatar
Ok I'll have to check into that tephra mod. That would be a great alternative. My IC sprayer is not working anyway, since i upgraded the intercooler.
Old Feb 8, 2010 | 04:22 PM
GST Motorsports's Avatar
As long as you still have the ICS switch in the center console still wired in then you can use it to tune switch maps via the Tephra roms.
If not, you can wire in a switch/button.
- Bryan
Old Feb 22, 2010 | 10:09 PM
Chris Moore's Avatar
Or use TPS
Old Feb 22, 2010 | 10:11 PM
kanyonkid's Avatar
or just invest in a tactrix cable and switch ur maps like that
danieljgermer
Aug 4, 2016 05:50 PM
Tanman1986
Sep 5, 2015 02:52 PM
Evo442
Dec 26, 2006 08:47 PM
justchil
Jun 22, 2006 10:46 AM
awitron
Dec 7, 2005 02:16 PM
