E85 Auto-Calibrate
Old Apr 16, 2010 | 02:08 PM
dyezak's Avatar
E85 Auto-Calibrate
I posted this in the ECU-Flash forum but think I put it in the wrong place, so I'll stick it here
I don't know what else to call it other than "Auto Calibrate for E85". But stock flex fuel vehicles do this. If you are at 1/2 tank of gas and fill up the rest of the way with E85 the ECU's calibrate for the change in fuel and automaticly adjust for the fluctuations in fuel composition. From what I can tell the ECU uses O2 feedback to determine the ethynol percentage in the fuel and adjusts the fuel map based on that. I may be wrong about that but it's how I understand it to be possible.
Is there any chance of us using a wideband feed to perform the same operation and automaticly adjusting the tune for ethanol content?
I was basing that statement on this article:
http://www.canadiandriver.com/2006/03/22/auto-tech-chevrolet-impala-e85-flex-fuel-system.htm[/URL]
GM has developed a Virtual Flex Fuel Sensor (V-FFS) software program that calculates the ethanol content in the fuel, instead of using a sensor to measure it. When the fuel level in the tank increases as the vehicle is refueled, the computer recalculates the percentage of ethanol in the fuel and automatically changes the air/fuel ratio. To do this, the computer temporarily stops the operation of other emission systems and monitors the oxygen sensors to determine ethanol content. The test is done several times until calculations remain stable. This can take several minutes when the engine is idling, but much less time at higher fuel flow rates.
Old Apr 16, 2010 | 02:44 PM
andrewzaragoza's Avatar
this has been discussed before on the ecuflash section. having an eca connected to the ecu and tephra doing his magic this is very possible.
Old Apr 16, 2010 | 03:03 PM
goofygrin's Avatar
It uses an ethanol content sensor. This basically determines the % of ethanol and the temperature of the gas and sends that as a signal to the ECU. The ECU reads that and then changes the timing in order to use the fuel appropriately.
Old Apr 16, 2010 | 07:11 PM
logic's Avatar
Your original thread..
As I said over there, mrfred was originally investigating this (I suspect it's what led him to spend so much time with the fuel routines in the first place), but I have a feeling real life has been catching up to him lately.
Chris@nolimitmotors
Evo 'For Sale' Electronics / Lighting / Audio
Jan 13, 2017 09:27 AM
Chris@nolimitmotors
EvoX 'For Sale' Electronics / Lighting / Audio
Jan 13, 2017 09:26 AM
jracer
Jun 15, 2016 05:08 PM
Chris@nolimitmotors
187
Dec 11, 2015 08:34 AM
formerSTIowner
Midwest Region
May 12, 2014 11:44 AM
