Question on injectors/fuel...
Old Jun 22, 2010 | 08:51 AM
JohnBradley's Avatar
I was just going to post that when Randy's car made this power last night it was actually more like E98 than E85, and it also has a 92K old filter. I would like to suspend my judgement of flow characteristics. I cant remember if we punched the pump on his car or not either.
So in my mind the jury is still out, and i will defer to Mychailo
aaron
Old Jun 22, 2010 | 01:17 PM
Fast_Freddie's Avatar
Veteran: Navy
AHH Jesus... decisions, decisions...
Old Jun 22, 2010 | 09:42 PM
iTune's Avatar
Originally Posted by Fast_Freddie
I have no clue then... my buddy Cary's car has most of the same mods as me except an FP black and he has FIC 1050s (low-z) he is at 85% IDC at 25 psi (single unmodded Walbro) and about 500 hp on Dynojet VDR on E85 that is why I am asking...
Mychailo what IDC are you seeing at your HP level?
That's me. I'm at 85-86% duty cycle at 25# which is right at 500whp. This Is with an unmodded walbro and stock FPR and Fic 1050s.
27# puts me right at 90% duty cycle.
Old Aug 10, 2010 | 06:40 AM
Appauldd's Avatar
reviving an old thread....but have you considered a fuel rail? The stock one has very small openings.
Just a thought.
Also, you could try routing a vacuum line directly from the intake mani to the fuel pressure regulator as a way to have rising rate fuel pressure. Some have said that the stock fuel pressure solenoid is only for startup....so I am not sure this will help.
Old Aug 12, 2010 | 01:21 PM
fre's Avatar
fre
I had an inline Bosch and a walbro 255 and the problem is that if you don't run the inline pump full time, the walbro will eventually burn out (1-2 years). If you run it full time then your idle will be craptastic. That setup was good enough for around 550whp though.
I just switched to a double in tank setup, using the evap line as a second fuel line and I gained 18% headroom over my old inline setup. I am on 1150cc FICs. I can hit 530whp now at only 80% duty cycle. I could probably hit 600whp before running out of injector now.
sqsquirrel248
Feb 22, 2017 05:07 PM
socalx_dsm
11
Jul 21, 2016 11:51 AM
buzzzin_IX
Jun 6, 2016 12:31 PM
dsmaniac
Mar 10, 2015 11:51 AM
