Known best injector?
Old Jan 6, 2011 | 10:26 AM
SavEVOIX's Avatar
Originally Posted by Pegasus
Highz is referring to the injectors being high impedance. These injectors are plug and play, but require the removal of the resistor pack. Here is a write up in "how to" section of the forums. Its pretty easy to do.
https://www.evolutionm.net/forums/ev...istor-box.html
Is this still required or is there now a plug and play harness out now? Reason I ask is I live in CA and may need to smog which would require me to switch to a stock "looking" injector if needed.
Old Jan 6, 2011 | 10:38 AM
phastsupra's Avatar
Im running the Injector Dynamics 1000's in the Supra and I got to say its a significant step coming off resistor boxes and Precision 1000's. Much easier to tune and way more consistent running. They provide you with dialed in voltage offset table for each set of injectors so it provides you with dead on offset tables. The start-up and idle on these is far superior to any large injector that i have ran. My vote is the ID1000 but i have never tried the FIC's.
Old Jan 6, 2011 | 01:08 PM
Dragracer187's Avatar
Another vote for ID1000's
Old Jan 6, 2011 | 01:18 PM
MR BURTON69's Avatar
High-Z Injector Resistor Pack Bypass
Here you go: http://www.szabaga.com/store/resistor.html ...just ordered this myself actually.
Old Jan 6, 2011 | 03:14 PM
mrfred's Avatar
The injectors are on the backside of the engine. I wouldn't worry about a smog tech recognizing non-stock injectors. Should be pretty easy to hide the PnP resistor pack plug as well.
The ID1000s apparently do well in other vehicles, but there are several not-so-great reviews on EvoM from people who know how to wrench and tune cars.
Old Jan 6, 2011 | 04:39 PM
SavEVOIX's Avatar
Nice thanks. Whats the diff between the two?
Old Jan 11, 2011 | 06:01 AM
Night479's Avatar
I would go with a 1400 blue max just b.c I have more fuel then not enough and injector duty cycles will be low, less stress but that's just me
Old Jan 11, 2011 | 10:32 AM
Fuel Injector Clinic's Avatar
The only difference in the two companies are they way the injectors are modified.
ID has 3 flow sizes to choose from and FIC has 10.
Both companies use same Bosch new technology injector.
Old Jan 11, 2011 | 10:44 AM
dbsears's Avatar
Originally Posted by GST Motorsports
Best plug n' play 1kcc in my book is RC.
Once you go up in size the Blue Max 1250/1350/1450/1550/ etc etc can't be beat for proper running and performance.
- Bryan
Have you had any starting issues with the RC1000s? I assume as many setups you have done with these they are pretty dialed in for E85 use. Would you still recommend them for a full bolt on (stock turbo) IX that switches from 92oct to E85 periodically?
Old Jan 11, 2011 | 11:06 AM
JohnBradley's Avatar
I think at the time Bryan was referring to ID1000s versus the RCs. Having owned and ran more or less every injector between 560s and 2150s I can say with great authority that my 2150s start better than RC1000s. Getting an injector in the 900/1100 range (if you are using high impedance) will only be better. In low impedance the FIC950 is better than the RC.
To answer a question that never did get covered, FIC doesnt overrate size. If anything they are a little smaller than advertised it seems compared to most of the other vendors.
Old Jan 11, 2011 | 11:07 AM
David Buschur's Avatar
I've tried them all. BY FAR the best injector I have found is the ID1000 and ID2000's. If it were up to me they'd be the only injector I ever used again. Unfortunately they are not cheap, so the guys who want the best buy them and the other people drag their ill running crap in here to try to have sorted out.
Old Jan 11, 2011 | 11:17 AM
dbsears's Avatar
Humm thats what I expected in a way. I had planned on going with RC1000's seeing as it's fairly easy to find really good deals on them. Availability being an issue for E85 for me I will only use it sparingly when I travel the distance to get some or go to the track. But hearing all the rave about the FIC 1100 high Z's I think it's probably just worth it to get those. If you get a chance Aaron can you PM me what kind of deals you get on those FIC's. Thanks for the response!
Old Jan 12, 2011 | 08:29 AM
The FIC 1100H's are a great choice! They also provide you with 20% more flow over the 900's giving you more head room down the road.
Old Mar 2, 2011 | 10:04 PM
dookiedang's Avatar
what about the FIC 850cc injectors?
http://www.maperformance.com/fuel-in...-126-0850.html
i want a mild build that wont waste so much gas haha.
i think 1000cc is a lil much on the gas.
plus they say its rated up to 600whp which my goal is like 400-450whp at the moment.
whats the difference between low impedience and high impedience??
Old Mar 2, 2011 | 10:08 PM
Aaron20's Avatar
FIC900 and FIC1100 are bothl high impedance and work great. They dont exhibit any starting issues when setup properly and allow you to max the fuelpump out. For the standard low impedance injectors anything from 950-1250 work well with the stock turbo depending on size of motor and ultimate power goal.
+1
