How to install GM Ethanol sensor with high flow fuel system?
Old May 6, 2011 | 08:26 AM
Stealthmatt's Avatar
Hello,
So I have two Bosch 044 pumps, that return fuel flow is 400 liters per hour, however the flex fuel sensor only flows a max of 200 liters per hour, when this is directly connected to the return line, it exponentially increases the fuel pressure - not good...
So what have people who have used the sensor done to combat this issue in a high fuel system scenario? any pictures/diagram appreciated...
Old May 6, 2011 | 09:16 AM
RoadSpike's Avatar
Originally Posted by Stealthmatt
Hello,
So I have two Bosch 044 pumps, that return fuel flow is 400 liters per minute, however the flex fuel sensor only flows a max of 200 liters per minute, when this is directly connected to the return line, it exponentially increases the fuel pressure - not good...
So besides it being ridiculous that you need 400 lpm of flow haven't you considered just making a bypass loop with 2 tee's?
Old May 6, 2011 | 09:33 AM
umm sorry i meant liters per hour lol - yeah that's a bit too high! the return fuel is 400 litres per hour and the ethanol sensor is 200 liters per hour
yes I have thought of a t-connectors but the problem is it needs flow through the actaul sensor...how do u make it flow through the sensor as well as the main hose...?
The fuel will flow back through the shortest resistance
Old May 6, 2011 | 09:42 AM
RoadSpike's Avatar
Just put the sensor on the straight part of the T's and the bypass on the 90. We don't really care how much fuel flows through it just needs enough to get a reading of the current fuel. Its not like your fuel is going to magically and suddenly change ethanol ratings.
Old May 6, 2011 | 10:26 AM
lol with flex fuel it will and changing to pump it will..the ethanol sensor is to tune and adjust the fuel profile accordingly
Old May 6, 2011 | 10:40 AM
RoadSpike's Avatar
And that takes what with your pumps like near the instant the pumps come on for the sensor to get fuel?
Old May 7, 2011 | 07:02 PM
1outlaw's Avatar
As RoadSpike indicates- you need very little to flow thru the sensor to get valid readings. If you set it up as he states then you will get plenty of flow thru it. It will be just as good and responsive as the OEM FFV setup.
Clipse3GT
44
Jan 29, 2022 09:54 PM
AMS
109
Jan 12, 2013 11:05 PM
DeatschWerks
Jul 31, 2012 03:23 PM
Ultimate Racing
EvoX 'For Sale' External Engine / Power
18
Oct 25, 2011 04:38 PM
TTP Engineering
60
Feb 24, 2010 09:53 AM
