Open or Closed Loop on E85?
Old Dec 8, 2011 | 02:32 PM
10isace's Avatar
I've been on E85 since April this year. I'm in open loop at all times to achieve 17.0:1 idle and cruise. I love it and it's been great!
EXCEPT this winter. Cold start, cold idle (dies and rpm fluctuates), bucking when cold, etc problems. I tried doing the things mentioned in cold start/idle threads (it got a little better). I tried messing with the timing. Car drives great when coolant gets to about 100+ degrees. That's about 3 minutes of warming up in the garage.
I need a clearer understanding of what's going on here. I'm confused with the ISVC and the Idler stepper tables, so I haven't touched them. Is there a tutorial or can someone shed some light on this? Does this have anything to do with being in open loop? And what IPW should I be at idle? I'm at 2.048. I see people trying to get below 1.28.
Old Dec 8, 2011 | 07:51 PM
10isace's Avatar
Also, what are you guys doing on E85, open or closed loop?
Old Dec 9, 2011 | 05:25 AM
Spec-Ops1's Avatar
I run closed loop with E85... but I still let my car warm up before driving the car...
Old Nov 9, 2012 | 10:57 AM
10isace's Avatar
Update:
I've switched to closed loop because I was getting ready to switch over to SD and I wanted to check my fuel trims to make sure they were good. They are. Anyhow, WOW, what a difference! It drives so much smoother. So smooth in fact, I've decided to hold off on SD.
As a bonus, I am getting 2-3 mpg better gas mileage. I've gone through 2 tanks of fuel so far, so it's pretty much verified.
Thanks Freddie at Spec Ops and Tom at tscomptuned for their input!
Old Nov 10, 2012 | 02:50 PM
Spec-Ops1's Avatar
Glad it is doing better!
Old Nov 30, 2012 | 10:38 PM
CDrinkH2O's Avatar
Wink
I recently changed from open (16.5:1 AFR) to closed loop on E85 and saw a 10% MPG improvement after reinstalling the EGR hardware. Mitsu engineers use technology that really works.
Old Feb 5, 2013 | 08:56 AM
Live4Redline's Avatar
I kind of wish there was a way to change the closed loop target afr for e85.
It's funny you would see a beter mpg on the richer closed loop afr then the appropriate open loop afr but I guess I could see how that's possible.
I'll be finishing up my tune here soon and I guess I do a few tests of my own.
Old Feb 5, 2013 | 09:32 AM
10isace's Avatar
There's a thread on here using WB for AFR targeting in closed loop with the Zeitronix WB. It was interesting, but IIRC most gave up on it. Too much fluctuating AFR's.
I think maybe CL is more effecient. IDK.
Old Mar 20, 2013 | 05:47 PM
211Ratsbud's Avatar
Fluctuates due to distance of the sensor away right? Place the wbo2 in the narrow band location for better results ? I'm thinking of doing this right now for 93
Old Mar 20, 2013 | 06:31 PM
10isace's Avatar
Cool! Update me.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Alchem1st
Jul 28, 2017 01:15 PM
Projectjdm
May 31, 2017 12:00 PM
nor11384
Feb 12, 2016 09:33 AM
Appauldd
Sep 21, 2015 08:39 AM
