E85 and 93....
Old Jul 26, 2012 | 02:49 PM
PrimerSdime's Avatar
Yes, it does matter. Every time you switch from e85 to 93 and vice versa there is varying amounts of the previous fuel left over. This is going to give you inconsistent fuel which in turn throws the fuel tune off. I know from experience.
Your ecu does not run in closed loop at wide open throttle.
Old Jul 26, 2012 | 02:52 PM
CurseDSM's Avatar
Then you do it your way I'll do it my way. And fyi my ecu doesn't run closed loop at all. I have no issues with drivability what so ever so whatever man I know what works
Old Jul 26, 2012 | 03:06 PM
If your ecu never runs in closed loop, than it doesn't use fuel trims.
Apparently you don't know what works, Tom at tscomp tuned your car.
Old Jul 26, 2012 | 04:58 PM
CurseDSM's Avatar
Obvioiusly I know that trims are based off injector scaleing. If injectors are scaled correctly shouldnt matter am I wrong?
Old Jul 26, 2012 | 04:59 PM
CurseDSM's Avatar
And yes Tom did tune my car, and yes we did do fuel trims when we did injectors and reguardless of what fuel I use they don't change much.
Old Jul 26, 2012 | 06:18 PM
4g63Evo8's Avatar
Talked to Tom...Basicly what I got from him was I Need 1000cc Injectors(I want this size dont need but want) a walboro 255(Should be big enough???) EvoScan to log my data once I have a working laptop again, This Grimmspeed 3 port ECU boost solenoid so its getting accurate readings, A better Wideband, ECUFlashed w/ tephra V7, and I should be all set? anyone want to correct me if im wrong on god forbid i missed something else i have to buy....thanks yet again guys...this is going to be a headache i can feel it
Edit: Do I need this Tactrix cable and openport 2.0 thing also? Im new to the Tuning aspect of the 4g63...I just want to know WTF I have to buy LOL someone make me a list please LOL thank you
Old Aug 7, 2012 | 06:52 PM
DropThatHammer's Avatar
Good read so far, good info!
Omg AWD
May 16, 2016 01:59 AM
fqjdmct9a
E85 / Ethanol
15
Feb 13, 2013 04:58 PM
Benja
15
Feb 11, 2011 04:59 PM
evo8nyc
Jan 21, 2011 02:09 PM
KrisR
14
Apr 12, 2007 07:33 AM
