Which injectors to buy...
Old Aug 31, 2013 | 08:11 AM
Skinchin13's Avatar
Ok so I want to run e85 on my evo. The car has stock turbo, walbro 255, arc intake, bigger front mount. Ams fuel rail... Just basic mods. Currently my car is on a 26 lb tune on 93. So which size injectors should I get and what is an affordable brand
Old Aug 31, 2013 | 09:00 AM
ReaperX's Avatar
Question you need to ask is what are your goals? You need an injector that while meet the goal with some head room. You will need 950cc minimum, must run 1050cc. I personally use fic 950cc, they meet my goals with some head room. I am fairly local to you if you need any assistance.
Old Sep 1, 2013 | 06:28 AM
Skinchin13's Avatar
Well as of right now with the 93 tune I have the car is making 313 awhp. I plan on putting GSC s1 or s2 cams in the car. Eventually I want to be in the 400awhp range.
Old Sep 1, 2013 | 03:50 PM
ReaperX's Avatar
1050's should meet your goals. If you want room to build go for 1200's.
Old Sep 1, 2013 | 04:01 PM
paulekas's Avatar
deatschwerks-1300cc-injectors for sure and will have room for power in the future up to 600whp
Old Sep 1, 2013 | 05:54 PM
Skinchin13's Avatar
Will my walbro 255 be enough for the 1200cc injectors. Also do I need to upgrade my fuel lines? Once I go e85 I don't plan to go back. Thanks for all the help guys.
Old Sep 1, 2013 | 06:06 PM
paulekas's Avatar
your injectors will be fine
single walboro is good up to about 420whp on e85 fuel lines are fine just get fuel rail and u will be good to go
get this one injectors and fuel rail
http://www.speedelement.com/index.ph...emart&Itemid=1
Old Sep 1, 2013 | 06:27 PM
Evosick2332's Avatar
I recommend going with 1150cc injectors. That is what I run on E85 and so far so good. Here are my current mods for reference.
-Turbo back exhaust
-AMS LICP
-AGP 3.5" FMIC
-3" JMF Intake
-Aeromotive 340 fuel pump
-FIC 1150cc injectors.
My car makes 357hp/359tq on the Mustang Dyno right now. I suggest going that route
Old Sep 2, 2013 | 04:32 AM
JaYr_EvO9's Avatar
-Turbo back exhaust
-AMS LICP
-AGP 3.5" FMIC
-3" JMF Intake
nice number i wanna run e85 but with cams hopefully be around 400+ i know my injectors are kinda small but for now i hope it can happen !!!!!
Old Sep 3, 2013 | 08:35 AM
Fuel Injector Clinic's Avatar
Like some others have said, something in the 1100-1150cc range is a perfect fit for a 400 whp E85 setup which also allows you a bit of headroom so you're not totally maxed out. The Evo 9 came with low impedance injectors so you can choose a set of those as a drop in replacement and they should work great for you.
You also have the option go to with our 1100cc high impedance injector with takes advantage of a newer design and technology. These have been very popular with many of the cars we sell to and can be installed in your car as a drop in solution as well. The only difference is you will also remove your injector resistor box and replace it with our injector resistor delete plug which is quick and easy (or you can skip the plug and do some soldering if you prefer).
Either of these injector options will come with Fuel Injector Clinic's Data Match Technology, the most complete flow matching and latency value information available in the industry. You can read more about that here: http://fuelinjectorclinic.com/data-match-technology
If you have any questions I'll be happy to answer them here or you can give us a call at (561) 427-0082.
Old Sep 3, 2013 | 01:36 PM
NightCat's Avatar
I currently have FIC 1250 Bluemax on my 9 MR on E85, awesome injectors! no issues.
Old Sep 4, 2013 | 08:13 PM
kvansic162's Avatar
He is a good guestion for fuel injector experts. Is it possible to have an injector that is a low impedance but is a saturated disc type? I ordered a set of 1050cc low imp. peak and hold and recieved 1120cc low imped. saturated disk type- according to the data sheet that came with the new set.
Old Sep 16, 2013 | 04:56 PM
Skinchin13's Avatar
Decided to go with race compenents 1200cc low impedance. They had a deal I couldn't resist.
Old Sep 16, 2013 | 05:46 PM
iiEVO's Avatar
I would run FIC 1250's Kevin D at Evolution Dynamics always recommends FIC and they have been great so far on my evo.
bolt ons, cams, ported evo 9 turbo, e85 on 28lbs
Old Oct 11, 2013 | 09:23 AM
manden's Avatar
400hp you need to have more fuelpump. The 255 will be maxed there.
